Posted: Wed Nov 14, 2012 5:57 pm |
I have this connection and a set of GTI headlights on the way, can I use this to connect them up to my h4 connector? I've tried on the other forums but no one is replying
| peugeot 206 silver 1.4ltr lx | |
Posted: Wed Nov 14, 2012 5:59 pm |
if the little spade connectors fit onto the blubs spades then yes.
Posted: Wed Nov 14, 2012 6:04 pm |
I've used this to connect a set of angel eyes (which I give up on) and both the h1s worked using it and these seem to fit onto a h7 bulb too
Posted: Wed Nov 14, 2012 6:07 pm |
if the connectors fit to the h7 bulbs then they will work, just make a little hole in the the rear case of the lights, feed the cables in and connect them up, seal the hole bit of silicone.
red will be dipped and blue full beam iirc
Posted: Wed Nov 14, 2012 6:08 pm |
Awesome
Posted: Wed Nov 14, 2012 6:09 pm |
Thanks very much
Posted: Thu Nov 15, 2012 8:59 am |
Why bodge like this when for less then £8 you can get the 2 x grey H7 connector plugs & the 6 terminal pins from any Peugeot / Citroen main dealer & do the job correctly
Posted: Thu Nov 15, 2012 11:13 am |
Trade Rating: +13
