Latest: Mr-Koekwaus
Overall: 17125
Online Now [168]:
Visitors: 167
Today: 47016
Total: 100129744
Forums › The Car › 206 Talk › PAS fluid or ATF fluid?
PostPosted: Sun Nov 18, 2012 10:33 am Up
Went to my local Unipart shop the other day to compare prices of their PAS fluid. Bloke told me the 206 would just use an auto transmission fluid for the steering.
Does this sound OK? Which is right?
Halfords PAS fluid is £8 ish
Euro Car Parts PAS fluid = £22 (discount 30% from this though)
Unipart want £8 for the ATF fluid
Euro Car Parts £6.50 ish for ATF fluid.
PostPosted: Sun Nov 18, 2012 10:34 am Up
? i though you ask about this before?
yes they are just ATF fluid
PostPosted: Sun Nov 18, 2012 10:37 am Up
It might have been mentioned once before but I've never asked specifically.
PostPosted: Sun Nov 18, 2012 10:41 am Up
yeah the normal red pas fluid is basically the same as atf fluid
PostPosted: Sun Nov 18, 2012 10:43 am Up
then that could be me asked this question before Laughing
PostPosted: Sun Nov 18, 2012 10:44 am Up
I'm sure I started a topic about electric pumps...can't find that either.
PostPosted: Sun Nov 18, 2012 10:51 am Up
Modern electric pumps use a different thinner fluid but saxo/106 ones run ATF like belt driven pumps
PostPosted: Sun Nov 18, 2012 1:36 pm Up
Valvoline Automatic Transmission Fluid Dex/Merc 1l
Valvoline Automatic Transmission Fluid Type D 1L
So which one is right though?
PostPosted: Sun Nov 18, 2012 1:58 pm Up
first one.
you need dex III type fluid
