Forums › The Car › 206 Talk › PAS fluid or ATF fluid? |
Posted: Sun Nov 18, 2012 11:33 am |
Went to my local Unipart shop the other day to compare prices of their PAS fluid. Bloke told me the 206 would just use an auto transmission fluid for the steering.
Does this sound OK? Which is right?
Halfords PAS fluid is £8 ish
Euro Car Parts PAS fluid = £22 (discount 30% from this though)
Unipart want £8 for the ATF fluid
Euro Car Parts £6.50 ish for ATF fluid.
Posted: Sun Nov 18, 2012 11:34 am |
? i though you ask about this before?
yes they are just ATF fluid
Posted: Sun Nov 18, 2012 11:37 am |
It might have been mentioned once before but I've never asked specifically.
Posted: Sun Nov 18, 2012 11:41 am |
yeah the normal red pas fluid is basically the same as atf fluid
Posted: Sun Nov 18, 2012 11:43 am |
Edward wrote: |
It might have been mentioned once before but I've never asked specifically. |
then that could be me asked this question before
Posted: Sun Nov 18, 2012 11:44 am |
I'm sure I started a topic about electric pumps...can't find that either.
Posted: Sun Nov 18, 2012 11:51 am |
Modern electric pumps use a different thinner fluid but saxo/106 ones run ATF like belt driven pumps
| Team Impossible Possible
Posted: Sun Nov 18, 2012 2:36 pm |
Valvoline Automatic Transmission Fluid Dex/Merc 1l
Valvoline Automatic Transmission Fluid Type D 1L
So which one is right though?
Posted: Sun Nov 18, 2012 2:58 pm |
first one.
you need dex III type fluid
