Latest: sparrowdclxvi
Overall: 17139
Online Now [119]:
Visitors: 118
Today: 31416
Total: 113479532
Forums › The Car › 206 Problems › Back end is sliding out big time!! please help!!
ringer179
PostPosted: Wed Nov 21, 2012 2:13 pm Up
My back end of the car is sliding out big time but only when i turn right,the back end slides left.its like powering down on a rear wheel car!!
needs to be sorted before i ahave a accident!! i even spun the car on a roundabout!
I have also notice the car is sat at a slant passenger side down.
I thought it was crap rear tyres but have changed with front( better make) and still does it.also when i take off the handbrake on a hill it feels like only the drivers side drops before moving off and also seems like its only the passenger side locks on when i pull the handbrake driving along but havent tested this with wheel in air yet.not sure if this is anything to do with it.
Not sure on the rear suspension set up or anything on the 206 so any help will be much helpful before i kill my self or even worse someone else!!
Rather be late in this world than be early in the next!!
PostPosted: Wed Nov 21, 2012 2:16 pm Up
whats the millage on the car? Sounds like the bearings in the rear axle are collapsing.
ringer179
PostPosted: Wed Nov 21, 2012 2:24 pm Up
its the gti 180 53 plate and done 92,000. how easy is that job and would that cause the problems? any way of checking?
NICKST
PostPosted: Wed Nov 21, 2012 2:29 pm Up
Is it a silver one ks53 buy any chance?
ringer179
PostPosted: Wed Nov 21, 2012 2:32 pm Up
no mate,its black lol whys that?you had same prolem?
NICKST
PostPosted: Wed Nov 21, 2012 2:36 pm Up
Ye my silver on used to destroy its rear shocks about every 10000 miles had new rear axel bushes bearings the lot Peugeot could never figure out why it did it went threw 4 sets while I had it. But used to have the same problem your haveing when they went.
PostPosted: Wed Nov 21, 2012 2:38 pm Up
Easiest thing is to buy a refurbished axle, find a company that will offer a surcharge refund on return of your old axle. If you have the tools/knowledge to do it yourself, its not the most difficult task to complete. I think it's either 2 or 4 bolts that holds it in. Just need to undo the exhaust, brake lines and handbrake cables first.
ringer179
PostPosted: Wed Nov 21, 2012 2:45 pm Up
ok cool.going to be a pricey job then.
Do you know any companys to start looking for?
i live on the isle of wight so its hell of alot more difficult for me to get the part off and on the island Sad
Would that cause the slant as its very noticeable?
thanks for all your help
NICKST
PostPosted: Wed Nov 21, 2012 2:47 pm Up
With the slant that's why I'm saying shocks or maybe Damaged torsion bar.
PostPosted: Wed Nov 21, 2012 2:48 pm Up
Slant on the wheel? No
But the 'whole' car slanting, yes.
Check for play in the axle bearings before you replace it btw
ringer179
PostPosted: Wed Nov 21, 2012 2:56 pm Up
yes the whole car is slanting. whats the best way to check the play in bushes??
PostPosted: Wed Nov 21, 2012 3:16 pm Up
Bearings.....
Jack the car up so the rear wheel is off the ground and just tug on the wheel eg
6 o clock ( 12 + 6 ) and quarter past 9 ( 3 + 9 )
Broken spring at front maybe?
ringer179
PostPosted: Wed Nov 21, 2012 3:19 pm Up
ok thanks,just check like a wheel bearing then? will do it as soon as i finish work tomorrow.many thanks
PostPosted: Wed Nov 21, 2012 4:30 pm Up
Wheel bearings you spin and hold the spring......
nellyhaggis
PostPosted: Wed Nov 21, 2012 5:04 pm Up
I've just rebuilt my rear axle. I replaced the bearings myself for £40.
It's no easy job but I wasn't paying £200 for a new axle.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
