Latest: elelectricistadeMateo
Overall: 17127
Online Now [60]:
Visitors: 59
Today: 6038
Total: 100404258
Forums › The Car › 206 Problems › Ignition coils compatibility for a Gti 180
kernel
PostPosted: Thu Nov 22, 2012 12:46 pm Up
Hi everybody
I think my 4 months-old ignition coils are failing Shocked (had to buy a new ones)
I need to check them but it's hard to find another Gti 180.
I would like to know if I can use coils from any 2.0 Peugeot/Citroen with the 6-pin connection. Or maybe Gti 180 uses specific ignition coils?
The conector should be like this
and the coils look like this
Thanks for any info Smile
PostPosted: Thu Nov 22, 2012 1:16 pm Up
What makes you think there faulty?
kernel
PostPosted: Thu Nov 22, 2012 1:21 pm Up
goes on three cylinders when warms
I get P0300 code, and spark plugs are OK (checked)
any other reason to be on 3 cyl?
206++
PostPosted: Thu Nov 22, 2012 1:22 pm Up
injectors..
kernel
PostPosted: Thu Nov 22, 2012 1:36 pm Up
Might be, but P0300 seems a ignition failure, and the mechanic thinks it's not injectors thing... Confused
I may open another topic regarding the problem, but at the moment I would like to check if it's ignition coils, so any info regarding the compatibility issue would be great.
PostPosted: Thu Nov 22, 2012 5:22 pm Up
That code is a very generic code, I've had it several times before now, it's been coil pack and injectors.
As for using another coil, im 99.9% certain the 180 run's a different pack to the 138.
kernel
PostPosted: Fri Nov 23, 2012 8:42 am Up
any easy way to check injectors?
the problems appears after 2 minutes of warming up.
It doesn't appear with the car on Idle.
206++
