Latest: sparrowdclxvi
Overall: 17139
Online Now [169]:
Visitors: 168
Today: 47385
Total: 113656094
Forums › The Car › 206 Talk › F**king wind!!
F**king wind!!
fatboyslim
PostPosted: Thu Nov 22, 2012 6:33 pm Up
Ok getting out the car earlier and the wind whipped the door open
It made a nasty sounding bang as it stopped
Luckily the door didn't hit the wing so no damage done there
Only problem now is the door doesn't shut as it did
I can still close it but really have to slam it
When I push the door it doesn't close it stops short
I've not been able to have a good look at it yet as it's been too dark
But any ideas what might have bent/broken??
Yes I own a CC and I'm neither gay or a hairdresser!!
NICKST
PostPosted: Thu Nov 22, 2012 6:55 pm Up
Hinges have dropped lift the door up from the bottom till it meets that catch correctly.
DanT
PostPosted: Fri Nov 23, 2012 2:56 am Up
I feel your pain, a bin flew down the road and smashed straight into my old vts last time it was really windy
You might be able to slacken off the hinges slightly and lift the door a bit till it lines up, 2 people are easiest for this so one can keep it where it needs to be and the other tighten the hinge back up.
fatboyslim
PostPosted: Fri Nov 23, 2012 11:44 am Up
Well managed to have a look today at work during my break
It seems that the door is to high,it's catching right at the front
where the plastic mirror surround is and the window doesn't go back into
the rubber channel correctly but I can lower the window a bit then put it back up and it goes in fine
Could this be a hinge problem??
fatboyslim
PostPosted: Sat Nov 24, 2012 10:39 am Up
Any body got any ideas??
pug206lx
PostPosted: Sat Nov 24, 2012 2:33 pm Up
I've done this before on a 206, I never found out what it was though.
138Andy
PostPosted: Sat Nov 24, 2012 3:33 pm Up
well all the manufactures do when assembling the cars if a door isnt sitting correctly they wack it into place with a soft mallet
