Online Now [484]:
Visitors: 483
Today: 150085
Total: 152785021
Forums › The Car › Request a how-to › Cam
Cam
Deano
PostPosted: Thu Nov 22, 2012 9:48 am Reply with quote Up
Hi does anyone know a how to for changing cambelt 206 gti 140 do u need and special locking tools or is there marks ? Question
L5_UKS
PostPosted: Thu Nov 22, 2012 10:08 am Reply with quote Up
You need the correct tools todo it and if you don't know what your doing I would really suggest you let someone who does do it.
PostPosted: Thu Nov 22, 2012 10:17 am Reply with quote Up
I would let a garage do it tbh mate, when you do have the belt change i'd recommend replacing the water pump as well
Deano
PostPosted: Thu Nov 22, 2012 10:18 am Reply with quote Up
I can change them on most cars just not done one on a pug before as I only fix cars in my spare time but I will just get the tools and get a Haynes I should manage I will have my mate with me who is a mechanic it's just I am not familiar with these so I just gettin advice off people who know
Deano
PostPosted: Thu Nov 22, 2012 10:21 am Reply with quote Up
Ye I though I will do that anyway might aswell do the lot why it is out I might do the rest then take it down to my mates garage for him to put belt back on
PostPosted: Thu Nov 22, 2012 1:13 pm Reply with quote Up
Tippex and drill bits do me for locking everything
As i cant ideally take the tools home incase it laps over to another evening
PostPosted: Thu Nov 22, 2012 1:28 pm Reply with quote Up
Most difficult part of the 138 GTi cambelt change is getting the covers off. It's tight with the air conditioning pipes removed it's impossible with them still there so you have to shift the engine off it's mounts to make space.
imjeeves
PostPosted: Thu Nov 22, 2012 2:33 pm Reply with quote Up
Get a Haynes manual and its not too bad. Use drill bits and tip-ex to mark the timing and you cant really go wrong.
PostPosted: Thu Nov 22, 2012 3:16 pm Reply with quote Up
Haynes manual covers the belt change in a 307 though. It overlooks the access problems in the 206.
Deano
PostPosted: Fri Nov 23, 2012 1:07 am Reply with quote Up
Ye that's ok I will have the engine out of the car is the holes for the locking tools on the side of the block because on fords they on front under alternator
Deano
PostPosted: Fri Nov 23, 2012 3:28 pm Reply with quote Up
Plz the time is getting nearer has anyone got any pics of the holes for the timing pins and how do u lock camshafts
PostPosted: Fri Nov 23, 2012 4:09 pm Reply with quote Up
Cam pulleys have hole in them to lock them.
Deano
PostPosted: Fri Nov 23, 2012 4:16 pm Reply with quote Up
How do u lock crankshaft hopefully I will have engine out tomorrow so I will be able to have a good look is they any marks or just lock them at top dead centre
macj
PostPosted: Sat Nov 24, 2012 12:15 pm Reply with quote Up
old trick ..... hold a stanley knife against the belt on idle in the centre of the belt until it is in two pieces. Stop engine and slacken tensioner. Remove outer piece of cut belt and slip new belt on halfway. Second half of old belt holds the timing in place. Cut off second half of belt and slip new belt on fully. Tighten tensioner
The above method is simply a quick way to change a belt without the proper locking devices and should only be attempted if you are confident the original timing was ok and you are of a reasonablly adept in mechanical issues..... Shocked
Deano
PostPosted: Sat Nov 24, 2012 12:43 pm Reply with quote Up
The only thing is mate the engine will be out of the car it is coming Monday but I will keep that method in mind for future
  Quick Reply
Username:
Message:
Quote the last message
