Posted: Sat Nov 24, 2012 11:38 am |
Need help.. Rear axle on my 1.1 is knackered .. I bought the bearing repair kit from Peugeot fitted it this morning but the shaft on the beam where the bearings sit on is the problem I seen a kit on eBay that includes a replacement shaft. Does anybody know how to change the shaft on the beam?
Would appreciate some help guys
Posted: Sat Nov 24, 2012 11:45 am |
you need proper tools to do it.
normal garage or even dealer will not be able to do this.
Posted: Sat Nov 24, 2012 11:49 am |
What tools? And who would do it for me then?
Posted: Sat Nov 24, 2012 11:51 am |
Recon rear axle with a warranty is always the way to go with these.
Unless you have access to the correct tooling for repairing a worn axle there just not worth bothering with.
Posted: Sat Nov 24, 2012 11:55 am |
proper big size hydraulic puller and press.
The cross membrane arm will be pulled out together with the stud.
so forget to rebuild it yourself, it is impossible.
Posted: Sat Nov 24, 2012 11:57 am |
| Seabook wrote: |
We have both at work
Don't get used that often but there both handy bits of kit to have in a workshop
Posted: Sat Nov 24, 2012 11:58 am |
Oh s**t ok was worth asking the question cheers lads
| MrBSI wrote: |
| Seabook wrote: |
Don't get used that often but there both handy bits of kit to have in a workshop  |
so you can do him a favor then
Posted: Sat Nov 24, 2012 12:01 pm |
| Seabook wrote: |
| MrBSI wrote: |
| Seabook wrote: |
so you can do him a favor then  |
No chance, I wouldn't even bother rebuilding my own let alone somebody elses
If it was my own car i'd just order up a recon beam & fit that instead.
Posted: Sat Nov 24, 2012 12:09 pm |
Haha worth a try sea book. I'm just gonna get a recon one off the web much easier less hassle
Posted: Sat Nov 24, 2012 3:46 pm |
Get a second hand axle job done!!
Posted: Sat Nov 24, 2012 4:33 pm |
Trade Rating: +59
| iainlovatt wrote: |
| Get a second hand axle job done!! |
False economy.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sun Nov 25, 2012 8:50 am |
Secondhand axle will cost between £80 & £100 non abs normal drums, reconditioned £250. All plus delivery, depends on age of car, how long you want to keep it and if you have the money for a recon. I fitted a secondhand and two months later the bearings went again, lucky it was covered by a 3 month warranty.
