Posted: Sat Nov 24, 2012 9:45 am |
I searched the forum and google for a solution to my problem but found none so here it is.
Last night after listening to music for quite some time (engine off) I started up the car, it barely started after making that distinct sound as if the battery was flat. I need to change the battery pretty soon, but that's not the problem.
The A/C was on 28 degrees but it started blowing only COLD air. It did this a while back, but it came to its senses in like 2 days without me doing anything to it.
So far I tried:
Opening the coolant cap and letting the engine run for 5-10 mins while reving it
I tried bleeding the coolant system by unscrewing the little brass screw on the thermostat housing
It's a 1.4 if that makes any difference.
I need help ASAP please!
Thanks, Chris.
Posted: Sat Nov 24, 2012 12:36 pm |
A/C is air conditioning? It's supposed to be cold. Turn a/c off and then you'll have hot air coming through.
Posted: Sat Nov 24, 2012 12:41 pm |
| lmilligan wrote: |
| A/C is air conditioning? It's supposed to be cold. Turn a/c off and then you'll have hot air coming through. |
AC works for all temperature's, it doesn't just make the air colder
Posted: Sat Nov 24, 2012 4:32 pm |
| MrBSI wrote: |
| lmilligan wrote: |
AC works for all temperature's, it doesn't just make the air colder  |
alright just never heard anyone say oh it's cold let whack the ac on full blast
Posted: Sat Nov 24, 2012 6:22 pm |
OK, I'll rephrase it...
Heating doesn't work, I tried turning it off, on, I changed the temp to cold back to hot, I changed to "eco" back to A/C...nothing works.
Posted: Sat Nov 24, 2012 7:15 pm |
Trade Rating: +16
blower may be broke? just so happens i have on for sale
£30
Posted: Sun Nov 25, 2012 3:15 am |
Can you feel warm pipes under the dashboard?
Posted: Sun Nov 25, 2012 4:10 am |
| anton1989 wrote: |
£30 |
If the blower were to be broken wouldn't it stop blowing any air? It still works but only with cold air.
| Edward wrote: |
| Can you feel warm pipes under the dashboard? |
Nope, I can't say that I do.
Posted: Sun Nov 25, 2012 5:24 am |
| lmilligan wrote: |
| MrBSI wrote: |
| lmilligan wrote: |
alright just never heard anyone say oh it's cold let whack the ac on full blast  |
You just don't understand how ac really works
Posted: Sun Nov 25, 2012 1:23 pm |
It was a simple electrical fault behind the A/C display. It's now fixed.
