Posted: Sun Nov 25, 2012 2:04 pm |
I've had this problem for ages now but because it's colder and my windscreen inside and out is condensed and even frozen at time I need this sorting
The blowers dines work until the car is really warm around 90 degrees then kick in, otherwise they may work for a split second and stop again
Can anyone shed any light on what could be causing this problem?
Posted: Sun Nov 25, 2012 2:31 pm |
Blower motor could be playing up. Resistors worn out or could just be temperamental fuse / relay.
Posted: Sun Nov 25, 2012 4:15 pm |
Could be your ignition switch on it's way out. Mine use to do this until I couldn't remove my key from the barrel. Ended up having to replace the barrel and switch. The switch was burnt out so I think it may have something to do with the heater as it didn't work when the key got stuck.
| You never really learn to swear until you learn to drive | |
Posted: Sun Nov 25, 2012 4:22 pm |
Try the resistor first, common item to fail
| Team Impossible Possible
Posted: Sun Nov 25, 2012 5:35 pm |
Ill give these all a look over
Easy job to replace the parts?
Thanks guys
