Online Now [222]:
Visitors: 220
Members: 1
Today: 38850
Total: 155757480
Forums › The Car › 206 Problems › Blowers only work when car is really warm
PostPosted: Sun Nov 25, 2012 2:04 pm Up
I've had this problem for ages now but because it's colder and my windscreen inside and out is condensed and even frozen at time I need this sorting
The blowers dines work until the car is really warm around 90 degrees then kick in, otherwise they may work for a split second and stop again
Can anyone shed any light on what could be causing this problem?
Uz
PostPosted: Sun Nov 25, 2012 2:31 pm Up
Blower motor could be playing up. Resistors worn out or could just be temperamental fuse / relay.
ukskater01
PostPosted: Sun Nov 25, 2012 4:15 pm Up
Could be your ignition switch on it's way out. Mine use to do this until I couldn't remove my key from the barrel. Ended up having to replace the barrel and switch. The switch was burnt out so I think it may have something to do with the heater as it didn't work when the key got stuck.
PostPosted: Sun Nov 25, 2012 4:22 pm Up
Try the resistor first, common item to fail
PostPosted: Sun Nov 25, 2012 5:35 pm Up
Ill give these all a look over
Easy job to replace the parts?
Thanks guys
