Online Now [1310]:
Visitors: 1309
Today: 127666
Total: 150434875
Forums › The Car › 206 Problems › Cambelt change
Cambelt change
Deano
PostPosted: Wed Nov 28, 2012 4:14 am Up
Right thankyou for all your help with me changing my engine and giving me info on my new 206 finally there just the cambelt to do and engine back in but at the moment I have all the looking pins in place I just want to know how to slacken off the tensioner and how to retighten the tensioner And again thank you for all your help
PostPosted: Wed Nov 28, 2012 7:47 am Up
Cambelt tensioner?
Is it the off-centre + spring&pointer, or just off-centre?
Deano
PostPosted: Wed Nov 28, 2012 8:25 am Up
I think it's just sting and pointer it's got a hole where a Allen key or something can fit in
PostPosted: Wed Nov 28, 2012 8:32 am Up
The way it works is you have to make the pointer lined-up with the marker-hole on the back-plate.
(NOT the smaller locking hole or the notch that fits onto the side of the engine)
You do this by adjusting the off-centre by turning the whole assembly with an allen-key, then tightening the centre nut to 25Nm iirr.
To take it off just undo the center nut.
For the V-belt tensioner grab the pulley-nut with a socket to push back and insert the locking pin.
I would do the water pump while you're at it.
WARNING: Get this job wrong and it's bye-bye pugy of course.
Deano
PostPosted: Wed Nov 28, 2012 9:17 am Up
Of course so when I put new belt on and re undo nut it will tension the belt automatically after a few turns by hand thanks for your help hope everything goes ok tonight then have u go any pic of the pointer showing which mark to line it up with
PostPosted: Wed Nov 28, 2012 10:25 am Up
No.
Deano
PostPosted: Wed Nov 28, 2012 12:02 pm Up
onSo how do u retension the belt
Deano
PostPosted: Fri Nov 30, 2012 3:16 am Up
It ok I found all the info I needed quite easy job really the whole job has been easy I have done harder engine and cambelt changes
PostPosted: Sat Dec 01, 2012 8:04 am Up
Good. Smile
