Online Now [3003]:
Visitors: 3002
Today: 176047
Total: 153015585
Forums › The Car › 206 Problems › white dials on 206 Sport (2006)
deb1974
PostPosted: Thu Nov 29, 2012 3:40 pm Up
does anyone know if all 2006 sport models should have white dials? if you've seen my previous post you will see that I've bought a car which I am having serious doubts about - the one i've bought doesn't have white dials but log book says its sport model (and it has all the other sport kit). just trying to work out if it's dodgy or not.
lukecalderon
PostPosted: Thu Nov 29, 2012 4:27 pm Up
It could be a case that a previous owner has replaced the dials in favor of the current ones, due to interior styling, or to replace damaged dials.
deb1974
PostPosted: Thu Nov 29, 2012 4:48 pm Up
thanks - I'm concerned it could relate to the mileage being clocked as things wrong mechanically with car don't fit with the low mileage it has.
lmilligan
PostPosted: Thu Nov 29, 2012 5:26 pm Up
Think they do mines a sport and I know someone else who has one who has the white dials also
lukecalderon
PostPosted: Thu Nov 29, 2012 5:34 pm Up
I believe, (not 100%), that if a new dash unit is purchased and had a lower mileage on it, then it will adjust its indicator to show the original mileage for the car; however if you buy a dash unit that has more miles on it than the car does, then the indicated number will not change to the correct mileage, and stay on the higher one.
I guess the only thing you could do is to go through the service history and check the mileage at each stage and try and estimate from that what you think it should be at.
PostPosted: Thu Nov 29, 2012 6:00 pm Up
The mileage is logged in the BSI unit and if you put clocks in with a lower mileage, it should go to the correct mileage. If you put clocks in with a higher mileage, it automatically goes to that mileage. Odd system, but it prevents clocking.
The mileage should also be recorded on the MOTs, so you should be able to check up on here.
You can see what your car left the factory with on Servicebox.
If you want, PM me your VIN and I'll send you the characteristics that are listed for it.
DeadEyePaul
PostPosted: Fri Nov 30, 2012 5:37 am Up
Mine is a sports model
click.infospace.com/Cl...577919392D
Bigbenj_08
PostPosted: Fri Nov 30, 2012 12:34 pm Up
My 2006 sport model has black dials.
Aegean Blue 1.6 16v Sport
Deano
PostPosted: Sat Dec 01, 2012 3:43 am Up
Go on google and type in check previous mot and u can go back and look at all the mot and see what the readings are on there
PostPosted: Sat Dec 01, 2012 5:16 am Up
Why go on Google and search when I have already posted a link to it.
