Latest: sparrowdclxvi
Overall: 17139
Online Now [124]:
Visitors: 123
Today: 14127
Total: 113254575
Forums › The Car › 206 Talk › 2004 1.1 206 Clutch Change?
James28
PostPosted: Sat Dec 01, 2012 11:14 am Up
Bit of a long shot, but just wondered if there was a guide on how to change the clutch's on these kicking around on here at all?
Friends clutch has gone, been quoted £370 at a garage to have it replaced, is this a reasonable price?
Only experience I've had of changing clutch's is on Renault Clio's, which you have to drop the subframe to get the gearbox out, so had a long book time and as such garages quoted quite a lot. Is it similar in 206's?
PostPosted: Sat Dec 01, 2012 1:49 pm Up
Dont need to drop the subframe on a 206, pretty simple job, can be done in a morning if you know what your doing, but even if you dont shouldnt take more than a day
PostPosted: Sat Dec 01, 2012 2:04 pm Up
I paid £160 for my 206 clutch change - obviously labour only. Cash price too.
PostPosted: Sat Dec 01, 2012 2:16 pm Up
Book time is 3 hours to do one on a TU engine
Diesels can be a little harder but its all the same at the end of the day
bezford
PostPosted: Sat Dec 01, 2012 5:44 pm Up
Does the larger size of the 2litre gti petrol 2002 make access and the job harder/longer
R.HYDE
PostPosted: Sat Dec 01, 2012 5:57 pm Up
Not really, isnt much extra on the gti to be in the way of the box.
James28
PostPosted: Sat Dec 01, 2012 6:38 pm Up
Thanks guys. So would you say that price is a bit steep? That is obvs price for kit and gearbox oil too.
Dont know whether to offer to attempt it myself, obvs only changed one before on a Clio!
PostPosted: Sat Dec 01, 2012 7:20 pm Up
Does seem a bit steep. If you have the tools readily availible then give it a go, most of it can be done with a decent socket set, the biggest one is the 32mm nut on the driveshaft.
Ciucur
PostPosted: Sun Dec 02, 2012 6:56 am Up
I got mine changed for £180.
£80 for the clutch itself and £100 for labour at a local garage in Northampton.
1.4 16v Black
PostPosted: Sun Dec 02, 2012 7:38 am Up
Whats the name of the garage then?
PostPosted: Sun Dec 02, 2012 9:40 am Up
Dont know how a business stays open of they are only charging £100.
kurosagi01
PostPosted: Sun Dec 02, 2012 11:12 am Up
I'm assume its a friend that works in garage.
PostPosted: Mon Dec 03, 2012 5:49 am Up
What?!
CBA to do it yourself Edward?! Smile
Ciucur
PostPosted: Mon Dec 03, 2012 7:24 am Up
I don't know the name of it, it was a small garage, I think they were polish, but they got the job done, rather quickly as well. Dropped the car off at 9 AM and picked it up at 2 PM.
I got a quote for £80 somewhere else but they said they would only be able to do it in 2 weeks time.
Nope, I didn't know anyone there. Smile
1.4 16v Black
PostPosted: Mon Dec 03, 2012 7:28 am Up
Where abouts in Northampton then?
