Online Now [448]:
Visitors: 447
Today: 125428
Total: 154682613
Forums › The Car › 206 Problems › Eco Mode, Non-Starter
206KL
PostPosted: Sun Dec 02, 2012 1:40 pm Up
Well I am annoyed with myself. Bought an 05 quiksilver hdi 16 yesterday (I know they are slated on here but be nice!) and today I tried to fit a new head unit.
Thing is I didn't disconnect the battery first, my fault I know, and now the car is in eco mode and won't start. It will turn over but it won't actually fire.
I know this has been covered a lot, but I'm not the most practical person with these things, so if anybody can give me any advice on how to go about fixing this without paying out lots of money.
PostPosted: Sun Dec 02, 2012 1:48 pm Up
Blown fuse, very common issue when people d**k around changing the head unit.
206KL
PostPosted: Sun Dec 02, 2012 1:51 pm Up
Which fuse is it that would have gone? F15?
And how sure are you that it's only a fuse, I'm dreading it being something much worse!
PostPosted: Sun Dec 02, 2012 1:54 pm Up
Because about every 3rd person that changes the head unit on a multiplexed 206 manages to blow the fuse Wink
The immobiliser runs through the same fuse, that's why it will turn over but wont fire.
206 immobiliser doesn't lock out the starter motor.
206KL
PostPosted: Sun Dec 02, 2012 2:02 pm Up
Thanks guys, panic over hopefully!
Is it fuse 15 that I should be checking? Because it looks remarkably small and i can't see an obvious break in the contact wire?
lmilligan
PostPosted: Sun Dec 02, 2012 5:41 pm Up
It's a 20amp fuse in the box under the steering wheel, can't remember which number though. Think 5 rings a bell but not too sure
lukecalderon
PostPosted: Sun Dec 02, 2012 6:00 pm Up
Sounds like a blown fuse - whip out the old multimeter and see if current flows through fuse 15 or 5 (take it out from the box first though!)
206KL
PostPosted: Mon Dec 03, 2012 7:27 am Up
Fixed - Was fuse 4 which had gone. Cheers for your help guys!
