Online Now [188]:
Visitors: 186
Members: 1
Today: 43004
Total: 155761531
Forums › The Car › 206 Talk › How long roughly..
How long roughly..
Forum Index › 206 Talk
NayNay1991x
PostPosted: Sun Dec 02, 2012 4:37 pm Up
Would it take to put a new clutch kit in, put some new CV Boots on the driveshafts if im right and also gearbox seals, Only reason im asking is i took my 206 to a new garage but wanted to know a time roughly
jk206
PostPosted: Sun Dec 02, 2012 4:39 pm Up
Why didn't you ask the garage when you took it in?
NayNay1991x
PostPosted: Sun Dec 02, 2012 4:43 pm Up
They said they would have it done by saturday but rang me saying while its up he noticed something leaking transmission fluid and needed new CV Boot kits and gearbox seals but just curious if its not done by tommorow Smile
206 1.4i GLX 1999
instagram.com/nay206pug/#
jk206
PostPosted: Sun Dec 02, 2012 4:44 pm Up
Shouldn't take more than a day really
PostPosted: Sun Dec 02, 2012 4:45 pm Up
Gearbox seals should ALWAYS be replaced on a driveshaft removal, they are one time only fit items
CV boots roughly take hour or so per one, book time is less but its bloody messy job
NayNay1991x
PostPosted: Sun Dec 02, 2012 4:48 pm Up
Cheers guys!
206 1.4i GLX 1999
DougalR
PostPosted: Sun Dec 02, 2012 6:24 pm Up
As said about 8-10hours
You can only plan so far, after that you have to take a few leaps of faith.
2001 206 GTi - Daily
2003 VW Golf .:R32 - toy
2001 106 Gti - in pieces.....
bezford
PostPosted: Sun Dec 02, 2012 7:24 pm Up
Have u seen the new cv boot fitting tool selling on good tool/parts sites?they elinate the full removal of the messy cvjoint part of the shafts as they still require removal of track rods.steering arms.anti roll bars amd the drive shaft is still pulled from the suspension and hub/brakes ...then u take the tool and stretch the supplied boot over the tool which in turn is threaded over the cv joint and shaft having cut away the old boot
..then the new boot is slid from the tool and is now on the drive shaft ready to be placed and tied into its finished position ovet the cv joint as if normal
...ive seen 3,2 expensive at £130ish and a budget one at £14 or less but im not sure if u need a specialy stretchy cv boot?
R.HYDE
