Online Now [616]:
Visitors: 615
Today: 119273
Total: 153992828
Forums › The Car › 206 Problems › Rear Wheel Bearing?
Rear Wheel Bearing?
Bigbenj_08
PostPosted: Sun Dec 02, 2012 2:06 pm Up
Hi all,
Got a constant but intermittent hum coming from the rear of the car...
Same point every revolution, gets quicker and louder with speed.
Took the wheels off today to make sure it was nothing obvious, but I can't see anything rubbing and there is no uneven wear on the tyres.
Thinking it may be a wheel bearing? But would the sound not be constant?
How much would a wheel bearing change be?
Or any ideas of what else it could be?
Thanks!
Aegean Blue 1.6 16v Sport
ukskater01
PostPosted: Mon Dec 03, 2012 4:36 am Up
Could be the shoes if the material has come away from the metal but I doubt it
VorTechS
PostPosted: Mon Dec 03, 2012 4:42 am Up
Staff - Vortechs
Hmmm got this on mine at the minute too, and did have the drums stick on once (although not repeated since) so I'm inclined to agree it's probably the shoes.
PostPosted: Mon Dec 03, 2012 4:52 am Up
A 1.6 petrol 16 valve 206 that the OP has should have rear discs fitted.
VorTechS
PostPosted: Mon Dec 03, 2012 4:56 am Up
Staff - Vortechs
So true ... Wink
Bigbenj_08
PostPosted: Mon Dec 03, 2012 5:00 am Up
Hi guys, yep sorry I have rear disks.
I was thinking it may be a sticky piston as the brakes do seem to bind in the mornings occasionally...??
But pad wear appears to be even.
Warped disk maybe?
bezford
PostPosted: Tue Dec 04, 2012 8:33 am Up
Arent 206's famed for rear axle problems???i fortunetly dont have ecperience of this myself but wouldnt it be a likely cause for these problems???just a thought?
R.HYDE
