Online Now [628]:
Visitors: 628
Today: 110194
Total: 153984456
Forums › The Car › 206 Talk › What would happen if i ground my sills off?
Forum Index › 206 Talk
Go to page Previous  1, 2
PostPosted: Mon Dec 03, 2012 4:16 pm Up
It would be an interesting modification to inform the insurance about. The premium would probably be slightly less than a convicted 17 yr old drink driver trying to insure a Bugatti Veyron.
PostPosted: Mon Dec 03, 2012 4:19 pm Up
If the car has been lowered so much that bits of the bodyshell need grinding of then there is no hope Rolling Eyes
D4NTP
PostPosted: Mon Dec 03, 2012 5:31 pm Up
Claws are really out over this question aren't they.
dan_manu
PostPosted: Mon Dec 03, 2012 5:36 pm Up
yurrr :/ mate id recomend keeping the sills as for insurance and mot purposes and also because its safer with them, just drive the car onto a 2 post ramp or block of wood and then jack it up then. it sounds to be ridiculously low tho
Rob2859
PostPosted: Mon Dec 03, 2012 6:24 pm Up
In all fairness it is probably easier just to sort the coilovers out. Mine is only down about 40mm but I couldn't live with any-more than that.
meady
PostPosted: Tue Dec 04, 2012 12:11 am Up
Trade Rating: +45
Why dont you just buy some new coilovers so you can raise it up a bit, seems a bit stupid wanting to cut bits of the car off as its to low.
And as has said it is the seam where the inner and outter sills are welded together so if you grind them off what is going to be holding them together???
TEAM - I HATE FACEBOOK Smile
PostPosted: Tue Dec 04, 2012 12:18 am Up
pnut_man wrote:
are they important? and if i couldnt grind the whole thing off maby half?
Lowered my car at the weekend and its only 1inch of the ground all round, need to loose the sills as my coilovers have seized up and i cant raise it up.
+++ Help not hinder please +++
haha good lad alex... noone else understands do they Rolling On The Floor Laughing
get some pics up of these new lows on here or facebook i wanna see
oh i'd bend rather than lose them all together though mate
Uz
PostPosted: Tue Dec 04, 2012 3:11 am Up
Just do what I did with the XSi completely bent them up around so they sat on the outer sill. They were painted black so you couldn't see them from a distance.
PostPosted: Tue Dec 04, 2012 6:29 am Up
Cut the sills off...you'll still be left with box sections under the floor that hang down the same amount!. Can you cut them off too?
206HdiGti
PostPosted: Tue Dec 04, 2012 7:04 am Up
LOL
I can't believe the question at all. The sill is part of the chassis which is welded on. You have increased the stress on the chassis by lowering it the amount you have. By all means make it weaker.
bezford
PostPosted: Tue Dec 04, 2012 7:40 am Up
Id be worried the floor would drop out at about 80 with a car full of mates carrying on...in fact it almost definately would...wot else do u reckon is holding floor up???anyway when u say sills i susspect u dont just mean the small thin joined crease at the bottom...u mean from the floor pan flat cut across which would be an interesting welding job at least...then cut a hole threw the bulk heads and thread the exhaust threw the interior because that would hang down...then cut the sump pan off and plate over the holes and as for the axles¿?¿?¿?¿?
I think peoples bad responses are a clue to how bad this idea is...just fix your susspension mate...for gods sakes.
R.HYDE
NayNay1991x
PostPosted: Tue Dec 04, 2012 12:11 pm Up
macca1411 wrote:
Cut them off and if you get hit by or run into something then you will increase the chance of the car folding in 2 and mangling you against the steering wheel.
Go for it, it could be entertaining.
lool
Page 2 of 2
