Latest: Worthy967
Overall: 17143
Online Now [560]:
Visitors: 559
Today: 126437
Total: 115026638
Forums › The Car › 206 Talk › PP2000
PP2000
LiamGTi180
PostPosted: Tue Dec 04, 2012 11:59 am Up
I am looking to get PP2000 and need to know a few things
Where is the best place to buy (genuine)?
Also I have heard about PP clones, is there a way to disguish a clone and what are the dangers of using one?
PostPosted: Tue Dec 04, 2012 1:39 pm Up
The price is the main difference between genuine and the clone. I'm sure Lee once said that the genuine PP2000 was about £3000. The clones start from about £70.
It's the lead that's the most important part. The software is available on the internet if you know where to look.
The latest software is Diagbox which has replaced PP2000. I think Diagbox works on Vista and 7, where as PP2000 will only run on XP.
The clones can cause problems with the BSI and I don't think you can do updates with it. If you get the genuine dealer spec, then you should be able to do anything the dealer does.
LiamGTi180
PostPosted: Tue Dec 04, 2012 1:59 pm Up
£3000!!! I have seen one on eBay. www.ebay.co.uk/itm/271107971414
LiamGTi180
I assume that's a clone :-/
PostPosted: Tue Dec 04, 2012 2:36 pm Up
I've got a clone lead. Not had a problem with it although I won't use it to change settings just in case the BSI screws up. It's OK for ABS and airbag fault finding and resetting the EML/airbag lights and it seems to access all the menus without any issues.
I think 99.9% of people with PP2000 on their home laptop are probably running a clone version.
PostPosted: Tue Dec 04, 2012 3:12 pm Up
Ive used my clone from Ebay without problems. Even used it for some BSI tweeks.
Macca, did you ever get diagbox to install on Win 7?
LiamGTi180
PostPosted: Tue Dec 04, 2012 3:54 pm Up
Cheers for your help. I am looking at doing several things. One thing is to activate the automatic locking when going over 5mph. I've tried holding the button etc so it must be deactivated
PostPosted: Tue Dec 04, 2012 4:24 pm Up
the anti hijack feature isn't on all BSIs.
Never got it sorted Steve. Tried vista and 7 but the crack didn't make any sense on either OS. Ran a dual boot system so I could run PP2000 on XP. Just bought a cheap XP laptop so i can run a stand alone system.
devotedsniper
PostPosted: Tue Dec 04, 2012 10:35 pm Up
I haven't had a problem with my clone, used it a couple of times for diagnostics and enabling features like trip computer on my 307.
Now a 2010 Renault Megane Coupe owner
LiamGTi180
PostPosted: Wed Dec 05, 2012 9:05 pm Up
Another quick question. I have purchased a kit now Smile it comes with pp2000 and diagbox. Can I use diagbox in the same way as pp2000 or is it completely different?
PostPosted: Thu Dec 06, 2012 6:09 am Up
Just stick with PP.
LiamGTi180
PostPosted: Thu Dec 06, 2012 9:01 am Up
Ok cheers for your help mate. Other than activating the auto locking and rear wiper when reversing what other things could be activated. I'm sure I recall someone saying they have activated a function which folds in the electric mirrors when the car is locked. That would be pretty cool Thumbs Up
