Latest: DanDan17
Overall: 17128
Online Now [67]:
Visitors: 66
Today: 39738
Total: 100640115
Forums › The Car › 206 Problems › Is it an injector faulty or wiring
LORDPSK
PostPosted: Fri Dec 14, 2012 5:13 pm Up
I have got a 2000 1.4 petrol 3 door Peugeot 206, got a misfire and irrational idle, cured the idle after changing the coil pack, spark plugs, air control valve, stepper motor, temp sensor unit, and the injectors, by resetting the stepper motor as I was not resetting correctly.
The misfire is still a problem, so it was suggested that I pull the plug off each of the injectors starting at the cam belt end as I was told this was No1 injector, anyway, pulled off the plug, turned off engine reconnected plug and repeated with No2 and so on, results as follows :
No1 change of engine noise but kept on running,
No2 engine cut out
No3 engine cut out
No4 no change at all,
So is it a faulty injector or wiring or something totally different.
Peugeot 206
PostPosted: Sat Dec 15, 2012 5:35 am Up
Two things
One get a code scanner
Two, who ever told you that is a complete idiot, PSA go from gearbox to cambelt. So cambelt end is number 4 NOT 1
LORDPSK
PostPosted: Sat Dec 15, 2012 5:46 am Up
Thank you for your reply and the correction about which one is No1 injector, but it did not answer the question of injector or wiring without spending mega bucks on a OBDI scanner as mine is a 2000 and OBDII did not come in till 2001 onwards.
Peugeot 206
PostPosted: Sat Dec 15, 2012 5:48 am Up
£30 on ebay, could have saved you wasting all your money on the other sensors..... Just saying
LORDPSK
PostPosted: Sat Dec 15, 2012 7:11 am Up
Could you suggest a suitable diagnostic equipment to work with my 2000 1.4 petrol or suggest a link please as I can only find OBDII scanners at that price. I have bought the software last week, just got o get he correct cable now at a reasonable price
Peugeot 206
PostPosted: Sat Dec 15, 2012 8:20 am Up
PP2000 will be your best bet. Clones cost about £70 on ebay. Search PP2000 or lexia and you will get quite a few results.
LORDPSK
PostPosted: Sat Dec 15, 2012 9:32 am Up
Thank you will look now.
Peugeot 206
LORDPSK
PostPosted: Sat Dec 15, 2012 9:47 am Up
Right solved the problem, faulty injector rail, changed for a spare I had and runs like a dream again
Peugeot 206
