Latest: sparrowdclxvi
Overall: 17139
Online Now [114]:
Visitors: 113
Today: 22677
Total: 113435274
Forums › The Car › 206 Talk › Lower engine cover/ belly pan
Johnbyron
PostPosted: Sat Dec 15, 2012 5:18 am Up
Now then everyone, I haven't been on in a while,
I apologise if this has popped up on a thread some time ago but if it has I sure couldn't find it.
Anyway I was wondering is a belly pan / lower engine guard available for the 206 ?? Were they fitted to a 206 from factory??
00budham00
PostPosted: Sat Dec 15, 2012 9:04 am Up
Far as I'm aware they never made any
PostPosted: Sat Dec 15, 2012 9:14 am Up
7013AQ £63.56
7013L0 £102.13
7013QK £262.39
00budham00
PostPosted: Sat Dec 15, 2012 9:26 am Up
Pricey plastic , ;0
PostPosted: Sat Dec 15, 2012 9:33 am Up
00budham00 wrote:
Pricey plastic , ;0
Pressed metal I think.
The cross member is £25
Johnbyron
PostPosted: Sat Dec 15, 2012 9:40 am Up
Thanks for the replies !!
That's a pricey bit of kit then,
Are they Peugeot prices ??
PostPosted: Sat Dec 15, 2012 9:47 am Up
Taken straight from servicebox.
Johnbyron
PostPosted: Sat Dec 15, 2012 11:24 am Up
Ah right , I found some plastic ones on eBay for £40 and upwards but I think I'll leave it to be honest
PostPosted: Sat Dec 15, 2012 2:13 pm Up
Fitted as standard to HDi's.
Johnbyron
PostPosted: Sat Dec 15, 2012 2:49 pm Up
Would a cover off a hdi fit a gti 180 ??
PostPosted: Sat Dec 15, 2012 2:54 pm Up
Not a good idea to install one as you'll interfere with the air flow and cooling.
bezford
PostPosted: Sat Dec 15, 2012 4:01 pm Up
If youve got a ramp and the inclination it would be a great diy project...if i get the money and time i might do my own out of ally sheet with a nice three rows of vents angled towards the rear...damned council should provide them with the size and number of speed bumps round here.
R.HYDE
Johnbyron
PostPosted: Sat Dec 15, 2012 4:27 pm Up
This did cross my mind but then surely the rad keeps the water / engine pretty cool and air is taken from the front grill and over the rad via the upper front grill so still a fair bit of cooling there but the air intake is a little more tricky as you know, I think I'll take a good look tomorrow and see if I can draw something up that won't have too much effect on the cooling or air intake. Smile
PostPosted: Sat Dec 15, 2012 5:30 pm Up
I'd have thought it was more to do with where the air comes out than goes in. As you say the air goes through the front, but can't be much good keeping that air in the engine compartment as it will just keep heating up and have no where to escape.
Might be worth having a word with Mac and asking him how having one on affects the rally car temperature.
bezford
Air intake will be fine as long as there's some perferations in the plate where the intake is located...i thought he meant the downforce factor when he said air flow...wether he meant it or not the downforce would improve with a skid plate fitted infact thete mighy even be a slightly noticable improvement with the drag reduced like this...
R.HYDE
