Latest: DanDan17
Overall: 17128
Online Now [124]:
Visitors: 123
Today: 22011
Total: 100541924
Forums › The Car › 206 Problems › Car Revving
Car Revving
97browng
PostPosted: Mon Dec 17, 2012 5:51 am Up
Hi All,
I have an issue with my car (206 2000 W Reg 1.1) that when I push the accelerator for some power the car revs really high but puts very little power into the car itself.
I did ask about this a while ago and I think it may be the clutch. However the car passed its MOT recently but only just as it was high on the CO2 emissions. So I was wondering if the issue might have something to do with the injection system rather than only the clutch.
I have a video which I have put on youtube and you can see what happens. All I have done is push the accelerator in slightly (not all the way in) and you can see the rev go up a load and then back down without any real increase in speed. It seems to do this on all gears (perhaps not 1st) and it seems to be getting worse.
So can you experts please take a look at the video on the below and let me know what you think it is and what the cost would be.
youtu.be/tmXJkj02maQ
The car has also cut out 3 times for no reason, I am driving and then I notice it has cut out. Each time it has done this it has been during cold weather and at the start of a journey (often when turning). It has had the coil and spark plugs replaced recently due to another fault. So I dont know if this is related or not.
Anyway any help as always is very much appreciated.
Gary
Tolkienfan001
PostPosted: Mon Dec 17, 2012 6:17 am Up
Trade Rating: +13
I would say clutch still! Might have other issues as well.
2005 1.4 16v Sport
Check out my 206 here!
Quarmbo
PostPosted: Mon Dec 17, 2012 9:50 am Up
Cutting out may be coolant temp sensor. Very cheap part to replace. With regards to the revving, are you resting your foot on the clutch when you drive?
Ford SportGay-A
oldskoolz
PostPosted: Mon Dec 17, 2012 10:11 am Up
idle control valve, clean it or get it changed, had the same problem on my old 1.4
Black 206 Gti. Soon to be 2.2
97browng
PostPosted: Mon Dec 17, 2012 10:42 am Up
Thanks for the replies gents.
Firstly is the idle control valve the cause of cutting out or revving? If the cutting out then fine if the revving then that throws a spanner in the works.
Also does anyone know where I can get these parts from (ICV and Temp Sensor) as cheap as possible. I don't mind fitting these myself if it is an easy job.
I have had a quote for the clutch and he said it would be £165 including parts, labour and VAT which seems a good price.
No I don't rest my foot on the clutch when I drive but my wife also uses the car if you think she may have done something.
Gary
Walton450
PostPosted: Mon Dec 17, 2012 11:28 am Up
i lost power to my car last weekend was just driving then the car just seemed to lose its get up and go, then about 10 mins later i just went. turns out it slipped a tooth on the can belt before it snapped.
I\'m Steve got a 2003 verve.
bezford
PostPosted: Mon Dec 17, 2012 4:09 pm Up
The high revs with no speed increase is almost defo the clutch plate or thrust bearing...defo something to do with clutch as the engines producing the power its just not getting delivered to the wheels so clutch is faulty
As for cutting out its choked up or maybe low battery power(a better battery may be needed)or idle control valve or temp srnsor as people have said however if u take car fora really good thrashing for15-20mins/miles this may fix the trouble as cars are used for too many short journeys these days and it upsets them..choking them up and the best cure for this is a really good thrash at a good high rev level for a prolonged period
. So if u dont want to go too fast but still need the thrashing/blowout rev high in 4th or3rd but for a good legnth of time...mine just started doing it so had a blowout and that problem is gone but i still need a better battery because its old and weak but the tick over problem is sorted by the blast out...
R.HYDE
97browng
PostPosted: Mon Dec 17, 2012 4:42 pm Up
Thanks for the replies all of you.
bezford I am glad to here you say it is def the clutch causing the revving issue so I will get that done this week (I have booked it in for Thursday). As I said the guy said it would be £65/£85 (depending on which make I want) for parts and £100 for labour which from what others have told me is not a bad price at all.
The cutting out does not happen often at all so it is something I can look at after xmas but I have taken the car for a good ride (over 600 miles in total) and it has happened since then. The battery should be fine as it is relatively new and in good shape so I think it must be one of the sensors. I see euro car parts sell both of them and the coolant temp price seems reasonable but the idle control valve is £60 while I can see ebay have them for £20 or under.
If anyone could point me to the exact parts I need for a good price it would be appreciated. Also any videos for changing the parts would also be appreciated as I am still a bit of a car novice.
Thanks Again
Gary
Gary
Quarmbo
PostPosted: Tue Dec 18, 2012 5:19 am Up
Search idle control valve on here - you don't necessarily need a new one, it may just need cleaning. There is a how to somewhere on here.
Ford SportGay-A
97browng
PostPosted: Thu Dec 20, 2012 11:09 am Up
Hi All,
So I thought I would update you on the situation (I know how annoying it is to read a forum and not know what fixed the problem). I have had the clutch replaced and so far so good (I will need to give it a proper test on the weekend).
Also when replacing the clutch the guy noticed that there was a leak coming from the water hose on the thermostat housing (landing on the gearbox). I saw it myself and indeed it had rusted through. He sorted it quite easily (he lengthened the pipe) for only £15. I am guessing this could have been causing some of my other issues but again I wont know until I have tested it. Does anyone here think this could be the cause of the cutting out issue?
Gary
bezford
PostPosted: Fri Dec 21, 2012 10:11 am Up
If its upset the temprature reading abilitys of the sensor it could be thrown off enuf for causing problems but not really a stall causing fault...its almost defo the idle control valve...try cleaning it and the connections or get a scrappeer semi new one...sorted...
R.HYDE
LORDPSK
PostPosted: Sun Dec 23, 2012 5:50 pm Up
Have you tried resetting the idle stepper motor, put drivers window down, disconnect battery (make sure you have radio code) leave for 10 minutes, reconnect battery, lean through drives window and turn on side lights to soft start bsi unit, leave 30 seconds, turn ignition on till warning light come on, wait 15 seconds and then start car, car should idle normal.
Peugeot 206
bezford
PostPosted: Mon Dec 24, 2012 6:40 am Up
Im not sure about the idle stepper motor but what youve described above is the bsi soft teboot procedure that will reset faults in the multiplexed system but as for resetting idle i dont know about that like...
R.HYDE
97browng
PostPosted: Mon Jan 07, 2013 6:31 am Up
Hi all,
Sorry for the long delay. Ok the revving issue (in the video) has gone so it was the clutch. However it is still cutting out. I have not cleaned the ICV yet (I will shortly) but before I do it I have some more information on the fault.
It seems that when I put the clutch down/am in neutral (especially if I am going quick and have to break suddenly) the revs drop very rapidly to about 500 and then go back to the normal idle of 1000. Most of the time when it drops the car continues but is on the brink of cutting out, however sometimes it will drop and cut out.
It does not do it all the time but I would say about 40% of journeys. It also does not seem to matter if the car is hot or not because sometime it happens at the start and the other day it happened after a 3 hour motorway journey.
Most of the time when I get the issue it happens for the complete journey and does not simply stop. A couple of days ago it was happening when I stared the car and the revs would go to straight zero and cut out. It did this for a few minutes and was then fine.
I will clean the ICV but I just want to be as certain as possibly that is the issue before I do work and then replace the part if cleaning does not work. Is there any way I can test the ICV or is cleaning/replacing the only option?
I have had the ignition coil replaced and spark plugs replaced recently so I do not think it is either of those.
Gary
Gary
bezford
PostPosted: Mon Jan 07, 2013 7:19 am Up
Mines just started with the same thing so ive adjusted the accelerator/throttle cable where it passes thru the plastic cover secured by the metal clip arrangement...the right place for adjustment actualy...so bonnet up car running and hold cable and ease clip off...then pulling cable up from plastuc cover gentley will increase engine speed/revs so find that sweetspot that is just above where it was originaly...but not too high were its over revving on tickover/idleing...it may take a bit of fiddling but mine went back with pin position in apparently the same place but must have been a fraction lower as its sorted the rev drop off totaly..
If u cant get the adjustment right simply tear a 2 inch square of thinnish card...tear a hole in the centre about a third of an inch round and tear a straight line from centre hole to edge...then simply slide clipped cable up slightly(THIS SHOULD BE CLIPPED AS CLOSE TO NORMAL IDLE AS POSSIBLE OR JUST UNDER GOOD IDLE SO THE CARD WILL LIFT IT TO PERFECT SPOT)and slide the card into place under the metal pin with the cable through the central hole in the card...
This should give a slight luft/rise in revs...if its not quite enuf add a second card on top of the first(MADE THE SAME AS FURST)...
If this helps anyone pleez let me know...cheers.
R.HYDE
