Online Now [509]:
Visitors: 509
Today: 166286
Total: 156518184
Forums › The Car › 206 Talk › Axle bearings, is this a new solution
Forum Index › 206 Talk
Fifer
PostPosted: Mon Dec 17, 2012 3:14 pm Up
While browsing the net i came across this website
buchapeugeot206.com.br/produto.html
Basically it replaces the axle bearings with a poly bush that runs the whole length of the axle shaft. It looks promising. Has anybody ever heard of this before.
1.4hdi 02
PostPosted: Mon Dec 17, 2012 3:25 pm Up
So with constant movement up and down you are telling me this works just as well without grease?
And has less play than a metal bearing?
I think dragging my face behind the car would be safer
Fifer
PostPosted: Mon Dec 17, 2012 3:37 pm Up
Well they grease the shaft but poly is self lubricating and if it machined to the same tolerances? Plus the loading will run the length of the shaft.
1.4hdi 02
PostPosted: Mon Dec 17, 2012 4:24 pm Up
well spotted Smile buuuuttt......
thats a terrible idea it has bearings not bushes originally for a reason. peugeots have been plagued with the dreaded axle bearings for years so im sure if it was that simple just to replace them with bushes they would of done it
bezford
PostPosted: Mon Dec 17, 2012 4:31 pm Up
Are u sure u dont use bearings and this bush thing to avoid the deflection of the shafts...i couldnt tell...is there a language setting on that site that i missed???
R.HYDE
Fifer
PostPosted: Tue Dec 18, 2012 2:06 am Up
I used Google translate. No bearings it's just a full poly bush that runs the whole shaft length
1.4hdi 02
PostPosted: Tue Dec 18, 2012 2:12 am Up
The material for that bush wont be as stiff as a metal bearing. So it's no good.
PostPosted: Tue Dec 18, 2012 9:23 am Up
loads of s***
