Online Now [380]:
Visitors: 379
Today: 159045
Total: 156873640
Forums › The Car › 206 Problems › Gti 180 loose gear change
Housty-gti180
PostPosted: Tue Dec 18, 2012 11:33 am Up
Hi just bought a 206 gti 180 and have a couple of questions if anyone can help would be much appreciated.
The gear change is very loose probably common but I'm not happy with it want to tighten things up with a quick shift but can't find one for the gti 180, anyone know where i can buy one? Was also looking for uprated gear linkage but from what I've been reading I'm lead to believe there is no linkage it's actually a cable, would replacing the cable tighten things up with the gear stick?
karimali831
PostPosted: Tue Dec 18, 2012 11:38 am Up
All gearsticks are loose on a 206 and there is no quick shift unless you get a new gearbox.
206 GTI 180
Housty-gti180
PostPosted: Tue Dec 18, 2012 11:52 am Up
So what I think is loose is just the way it was from new?
PostPosted: Tue Dec 18, 2012 12:49 pm Up
Whats the last 8 of your vin? As i honestly never knew that Laughing
Dont see why a retro fit off a older 180/gti couldnt be fitted
Schumi
PostPosted: Tue Dec 18, 2012 3:07 pm Up
GTI180 using cable shifting system. So I think one of your cable or cable holding bracket which is mounted top of gearbox slightly damaged. You can install only compbrake Quickshift. But this is really hard to install.
2005 206 RC RED
PostPosted: Tue Dec 18, 2012 3:12 pm Up
2.20 hours on service box supposedly?
bezford
PostPosted: Tue Dec 18, 2012 3:32 pm Up
Im sure ive read how tos or someone posting on here at least talking about fitting quickshift units etc. And they were doing them on all models???maybe recalling badly???
R.HYDE
