Online Now [450]:
Visitors: 449
Today: 151523
Total: 156866205
Forums › Tuning, Modification & Legal › Project Cars › Dirty Lucy (Diesel) 206
RossC413
PostPosted: Wed Dec 19, 2012 4:04 pm Up
Right been on here for a while now and all i have done is ask really daft questions :/ so time to change all that and do something decent on this site.
Bought my 206 Hdi 1.4. second car first was a corsa (spue) so already i have upgraded. car was compleatly standard. so much work was needing done. since i bought it pretty cheap too i have got a bit to spend Smile
first thing was to pick up the car, hit the moterway and boom problem. as soon as i hitted 50mph the rear wheel on the left hand side was wobbly as hell. stopped to check, wheel was not loose but the wheel bearing was, after closer inspection it had been like this since 60,000 miles, it was 84,000 when i bought it... so axle bye bye.... and then the new one was on.
Ripping out and instalation of the new/old axles in no picticular order
thats the first leg of the jorney much more has been done so ill update when i can also a few questions i have if anyone wants to help
1.tinted lights i am looking for some will the older styles lights fit onto my car? as i can get a set of them cheap and get tint spray
2.splitters will a clio one fit?
3. lights im looking for the masked ones were you only have 3 lenses? if you get what i mean where can i get them.
4. is re trimming door cards hard?
ok thats it thanks rate/hate
i drive a french car yes, they all said it would brake down, it did Sad
20Drift
PostPosted: Wed Dec 19, 2012 4:21 pm Up
Looking great so far!
1. Yes, the Phase 1 rear lights will fit right in there, no problem!
2. No idea :/
3. You could go 2 ways. One would be to mask them yourself, by dismantling the headlights, and then spraying the silver inside. Alternatively, you could buy a set. I think Valeo make them, but I have no idea where to get them from. You could ask on the 'Wanted' section, as some people may have some for sale!
4. Nope, relatively easy! Take a look at this to gauge if you think you're up to it. I've done it on a friend's 206 and it only took a couple of hours Smile www.206info.co.uk/Foru...art=0.html
Hope that helps!
RossC413
PostPosted: Wed Dec 19, 2012 4:34 pm Up
cheers, ah good ill buy some of the lights and use spray tint, ah ok ill look into it, ah ok good i have some funky ideas for interior cheers
PostPosted: Wed Dec 19, 2012 5:01 pm Up
Best colour for a 206.
The lights your describing are Morettes
You can buy masked Valeos or split your own and spray them up
There is a guide here, but unfortunately the pictures have been removed.
You can paint them any colur if you do them youself, but this is the sort of effect you'll get.
Domo
PostPosted: Wed Dec 19, 2012 9:30 pm Up
you look like you had an easier time changing your axle than i did on a mates using a trolley jack and two axle stands that we stuck under the sills.
also if you are looking a set of phase 1 rear lights i have a set for sale in excellent condition with back boards included.
think your looking morettes like macca said
PostPosted: Thu Dec 20, 2012 12:26 am Up
Car looks nice.
Andy_
PostPosted: Thu Dec 20, 2012 1:53 am Up
Nicest colour for a 206
Progress Thread
southwestchap
PostPosted: Thu Dec 20, 2012 3:06 am Up
What He Said
RossC413
PostPosted: Thu Dec 20, 2012 4:15 pm Up
cheers! the axle swap took 1hr! was easy!, yeah they are the lights i am after Smile will see fit santa brings me first!
right ok my car now is much diffrent, bought myself a second hand dial sorround for £2.00 and decided to sticker bomb it! well first try erm.... failed.
so got some plastic primer put on 2 coats and boom 10min later stickers stuck!
to say it looks ace! got more trim to do.
also while looking about i found a lovley set of these: car jacked up btw.
more to be added tomorrow maybe!
jayz206gti
PostPosted: Thu Dec 20, 2012 4:33 pm Up
Looking good dude. I bombed my interior on my old gti. Pics on here if you fancy a butchers
Upgraded from 138 to 180
RossC413
PostPosted: Thu Dec 20, 2012 4:46 pm Up
decent, how did you find for getting them to stick? btw were did you get the books?
jayz206gti
PostPosted: Thu Dec 20, 2012 5:06 pm Up
I got the books from amazon i think. It was trial and error. I gave it a few layers of clearcoat afterwards which helped it last
RossC413
PostPosted: Thu Dec 20, 2012 5:12 pm Up
yeah ive did the same for the finish, ok cool
RossC413
PostPosted: Tue Jan 08, 2013 3:56 pm Up
Update: went got a set of 205 gti wheels for £100.00!!!! think it was off here to.... anyhow came in a bit of a state but got them powder coated in white and now they are looking lush as hell!, set of T1R's and on the car it went with 205 wheel studs. gave the car a wash too and also got a cone filter, filters and thats it i think more parts to be added soon!
RossC413
PostPosted: Thu Mar 07, 2013 3:43 pm Up
wow ok lots has happened, got the rear mud flaps fitted looking sweet!, and then soon after i used them for real off roading by going into a field. :/ thankfuly not much damage, got it back to the garage and after a few phone calls some parts arrived and car was back on the road 1hr later :),
i have to admit sticker bombing was really tempting.... but i thought id best leave the wing for just now, looked up the paint code and found out id have to spend £60 on 0.5L of paint :/ needed it so i went bought it and havent had time to spray it
will add pics but photo bucket is down atm, will add asap
p.s never let your friend move your car he ripped off my mudflap :/
