Latest: heikkisj
Overall: 17126
Online Now [62]:
Visitors: 61
Today: 19724
Total: 100392413
Forums › The Car › 206 Problems › 1.1 MIL light on some times - P0203 and P0505
stevesey
PostPosted: Sat Dec 15, 2012 5:27 am Up
Hi
Engine light has been coming on intermittently (normally clears after re-start) on my daughters 206 1.1 (2002 '51 plate 65K). Just checked the codes and it is reporting P0203 and P0505.
Generic code tables report P0203 as cylinder 3 injector malfunction and P0505 as idle control malfunction.
Car has been running fine and idle speed is rock solid, no stalling reported.
Edit: Having listened with he bonnet up it is hunting very slightly at idle.
Plugs are due for a change (have been meaning to get around to that - so will do anyway).
Any thoughts?
Steve
stevesey
PostPosted: Sat Dec 15, 2012 6:56 am Up
Plugs changed now - gaps were pretty wide on the old ones - couldn't see any noticeable difference in the condition of number 3 plug. Slight hunting still seemed to be there after - although this stopped when I gave the idle value connector a push.
Will have to wait and see if the MIL light comes on again.
Assuming the P0203 is an injector issue what is it most likely to be - the injector itself for the injector loom.
Witty comment here!
bezford
PostPosted: Sat Dec 15, 2012 5:38 pm Up
Sorted it mate???
R.HYDE
stevesey
PostPosted: Sun Dec 16, 2012 4:51 pm Up
Monitoring - no sign of MIL light today. Will report back later in the week.
stevesey
PostPosted: Sat Dec 22, 2012 7:01 am Up
All good still - so assuming the codes must have been cause by a slight misfire (either plug on its way out or just the result of high load and wide plug gaps).
