Online Now [489]:
Visitors: 488
Today: 104411
Total: 105432802
Forums › The Car › 206 Talk › Throttle body cable
Throttle body cable
Deano
PostPosted: Sun Dec 23, 2012 8:09 am Up
Hi everyone I have searched on this but can't find exactly what I am looking does anyone know how to or a link to how to on setting the throttle body cable properly with the air box off the top I have set it so the cable is tight is this right? Crying or Very sad
PostPosted: Sun Dec 23, 2012 8:11 am Up
206gti.net/throttle-cable/
Deano
PostPosted: Mon Dec 24, 2012 4:21 am Up
Could anyone tell me how many notches there's is set on plz the tighter u set it the faster the acceleration but I don't know whether I do it any damage
DanT
PostPosted: Mon Dec 24, 2012 5:00 am Up
Which 206? If its the GTI it explains in the link above...you need a small amount of slack in it at rest, but the butterfly should open fully when the pedal is all the way down.
Get a friend to help won't take long at all.
PostPosted: Mon Dec 24, 2012 5:26 am Up
Just pull the outer cable until it hits the stop and slide the clip into place.
Deano
PostPosted: Mon Dec 24, 2012 7:06 am Up
Ye mate it's the 140
