Latest: Andyblue64
Overall: 17123
Online Now [43]:
Visitors: 42
Today: 17475
Total: 98021486
Forums › The Car › 206 Problems › can someone help identify these parts?
drunknmunky
PostPosted: Fri Dec 28, 2012 5:16 am Up
I thought I had destroyed my car as driving along and it said oil pressure insufficient cut out and lots of oil leaking. Thought it was the sump but after looking it appears to be this part here? Think it's something to do with the oil cooler as it attaches to the part in front of the radiator by metal pipes? Just need some clarification on what it is and would I be able to upgrade to a better oil cooler if I'm having to fix this?
PostPosted: Fri Dec 28, 2012 5:30 am Up
That's the air conditioning condenser unit... I think. Wink
drunknmunky
PostPosted: Fri Dec 28, 2012 5:35 am Up
Well how the he'll does oil end up coming out of it and cause insufficient oil pressure?
PostPosted: Fri Dec 28, 2012 6:06 am Up
Something to do with A/C. A/C doesn't use oil as the gas is the lubrication. Is there still oil in the engine?
PostPosted: Fri Dec 28, 2012 6:10 am Up
Is it still for sale?
drunknmunky
PostPosted: Fri Dec 28, 2012 6:13 am Up
Possibly depends what a mechanic says....
PostPosted: Fri Dec 28, 2012 6:15 am Up
That cylinder is the drier for the air conditioning. The metal pipes behind the bumper are for the power steering.
138Andy
PostPosted: Fri Dec 28, 2012 7:24 am Up
thats the AC bud, had to replace mine when i drove through a fence! its not really important had mine off the car for about 4 months before i fixed it
it wont be leaking oil thats just s**t that gathers on the top sticks to the grease
the pipe thingy you have circled just pushes together and is held in place by a spring! but same again its something to do with the AC
Tolkienfan001
PostPosted: Fri Dec 28, 2012 7:31 am Up
Trade Rating: +13
When I drove through a Fence!?!? You wrote that like it's an every day occurrence Rolling On The Floor Laughing
2005 1.4 16v Sport
Check out my 206 here!
138Andy
PostPosted: Fri Dec 28, 2012 10:38 pm Up
lol spun it out on a gravel track though a green metal fence around the "l'oreal products" factory Wink
Mattie-RS
PostPosted: Sat Dec 29, 2012 9:37 am Up
The oil has come from somewhere near that tho you'll just have to keep looking
PostPosted: Sat Dec 29, 2012 9:41 am Up
Maybe the seal on the fittings has gone and leaked the air con oil out.
drunknmunky
PostPosted: Sat Dec 29, 2012 10:11 am Up
It appears to have done that but then why would it cause the engine to stop? I'm having a look all round that area tomorrow see what I can gather from this......
There is a seal burst from the looks of it as there is a metal ring loose on the piping hut like I said how would it effect engine and oil pressure?
drunknmunky
PostPosted: Sat Dec 29, 2012 10:20 am Up
In the second pic you can see the metal ring on the pipe I have pointed out which is loose and I had never seen it like this before .... wonder how it's effected the car and made it stop though? Did get a strong weird smell in the car through the air con when it happened.
PostPosted: Sat Dec 29, 2012 11:20 am Up
My little ring was like that without any problem.
