Latest: DanDan17
Overall: 17128
Online Now [55]:
Visitors: 54
Today: 19481
Total: 100580158
Forums › The Car › 206 Problems › can someone help identify these parts?
Go to page Previous  1, 2
PostPosted: Sat Dec 29, 2012 10:32 pm Up
Edward wrote:
My little ring was like that without any problem.
Mine too.
And yes it is the dryer not the condenser (which is the big panel at the front like a 2nd radiator)
PostPosted: Sun Dec 30, 2012 5:26 am Up
Air con gas is under high pressure, so doesn't really leak, it would burst out. Is there oil in the engine? Has it been started since? You could try running the a/c. Does the oil have a smell?
drunknmunky
PostPosted: Sun Dec 30, 2012 6:21 am Up
Yeah well it kind of was a sudden burst and there was still oil in the engine but isn't anymore I don't think I'm going to have a look around that are for where the oil has come from failing this I don't know what else could have happened but something is causing there not to be enough oil pressure which is why I can't see it being this but when I had a quick lookthe other day I couldn't see anything else and this suddenly has oil around it? Which it didn't have before....
macj
PostPosted: Mon Dec 31, 2012 1:47 pm Up
Would my memory serve me correctly.... this condenser is on the same side of the engine as the crank pulley?...... I would check down by that.... the oil pump is on that end of the crank and has a blanking cap holding the relief spring in place..... would the oils have sprayed out from there and gone on the belts. You would lose oil pressure also. Check round the crank pulley
Page 2 of 2
