Online Now [1812]:
Visitors: 1812
Today: 246825
Total: 152014187
Forums › The Car › 206 Talk › Peugeot Fault Code Reader
Forum Index › 206 Talk
nellyhaggis
PostPosted: Sun Dec 30, 2012 9:50 am Up
Hi,
I need to buy a fault code reader for my 206. So I need one that will do the engine light, air bag, abs etc.
Can anyone advise which one to get?
Cheers.
Kevin.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Deano
PostPosted: Sun Dec 30, 2012 10:36 am Up
Peugeot planet on eBay mate does that and loads more
PostPosted: Sun Dec 30, 2012 11:31 am Up
PP2000 on ebay will be Chi na clone copy. Brilliant for most things on the 206 but beware of changing
configs in the BSI and esp. ECU.
Some actions like updating ECU firmware will not work as it requires access to PSA server.
You will also need a laptop running XP.
nellyhaggis
PostPosted: Sun Dec 30, 2012 11:51 am Up
I was looking at an Autel one as they would cover the Mrs Clio aswell.
Item number 200800200027
PostPosted: Sun Dec 30, 2012 11:57 am Up
The ones on ebay will do the job, mine is fine. Mine came with the software for Renault and citreon as well, forget what its called though.
What one have you got v9977?
nellyhaggis
PostPosted: Sun Dec 30, 2012 12:05 pm Up
I've got an abs fault which then developes a traction control fault.
Not bought a scanner yet.
I was hoping someone would recommend one!
richpowell91
PostPosted: Sun Dec 30, 2012 1:01 pm Up
How much would you use it? If rarely why not take it to a local garage and get them to scan it for you, shouldn't be much we charge 29.95 + vat.
PostPosted: Sun Dec 30, 2012 1:35 pm Up
Diagbox is the most up to date software which doesn't require XP to run, although I've not heard of anyone being able to get a cracked copy to run yet.
The basic Lexia/PP2000 setup from ebay does most people. I was running it on a dual boot system (Vista/XP) without any problems. Hardest part was setting up the drive partition, but I have no IT experience so struggled through using internet guides.
nellyhaggis
PostPosted: Sun Dec 30, 2012 3:25 pm Up
Well as a 206 owner Im going to be using it a fair bit.
I bought a cheap one to delete my engine codes which worked a treat.
Think im going to go with a Autel MD704 seems to do all things I want.
PostPosted: Sun Dec 30, 2012 3:53 pm Up
Lee got diagbox up and running. I just use the one i have at work if i ever need it Laughing
PostPosted: Sun Dec 30, 2012 4:20 pm Up
Make a note of how many times you clear codes. The limit is 50 on the 206, after which you won't be able to clear faults anymore.
