Latest: tc.206
Overall: 17147
Online Now [244]:
Visitors: 243
Today: 16222
Total: 116329777
Forums › The Car › 206 Problems › new car, broken display :-(
storm2284
PostPosted: Sun Dec 30, 2012 12:48 pm Up
Firstly hello! Got my first 206 yesterday although not a pug virgin, I do also have a 106 gti lol.
Anyway it's a cracking little car but the display isn't working we've found the issue with it but cannot repair it. I've been looking for a replacement part but am also struggling to source one the part number as far as I can see is 96443821zr can anyone suggest anything at all please? Many thanks
Kelly
richpowell91
PostPosted: Sun Dec 30, 2012 12:55 pm Up
It should have a ppt number on it, either 20, 30 or 40.
Are you sure its not repairable there's a guide on here on how to fix a faulty ppt30 display.
If not then it you will be just chancing your luck as to if any other replacement you buy will be faulty without the seller proving it, me and my friend were both after one and we went to a local scrapyard removed two from two 206's parked next to each other, the scrapyard wouldnt allow us to check so we paid for them £10 each, got back to my car mine worked his didnt but the scrapyard wouldnt take it back. Just down to pott luck in that situation.
iainlovatt
PostPosted: Sun Dec 30, 2012 12:56 pm Up
what display? PPT?
(My Garage)
storm2284
PostPosted: Sun Dec 30, 2012 1:01 pm Up
Well I've been looking on eBay and I can't find any that have the same part number. As far as mine goes it's the pads that have come loose and they can't seem to be able to re solder them sorry I'm not sure what you mean by ppt?
richpowell91
PostPosted: Sun Dec 30, 2012 1:11 pm Up
It should have ppt ** writen on it somewhere either 20 30 or 40
storm2284
PostPosted: Sun Dec 30, 2012 1:14 pm Up
I'm looking at it now and can see the sticker with the part number but nothing with ppt.
richpowell91
PostPosted: Sun Dec 30, 2012 1:19 pm Up
Okay in that case what shape is the unit
if its quite small and square in shape with a small screen its a ppt20
www.ebay.co.uk/itm/PEU...415997703e
if its long with a definative curve on the top edge of the black plastic part is a ppt30
www.ebay.co.uk/itm/PEU...3f2054f34d
if its long with a more rectangular shape is a ppt 40
www.ebay.co.uk/itm/PEU...257646d55a
storm2284
PostPosted: Sun Dec 30, 2012 1:22 pm Up
It's a 30 then lol thanks for that I've found several units for sale but none at all that match the numbers apart from one that has long gone
richpowell91
PostPosted: Sun Dec 30, 2012 1:23 pm Up
www.206info.co.uk/Foru...art=0.html
Have a look at that guide to make sure it cant be repaired before you buy a new one. If not as far as im aware so long as you get the sameppt type it doesnt matter on the numbers.
storm2284
PostPosted: Sun Dec 30, 2012 1:26 pm Up
Ah yes I see now! Yes the exact problem but it won't solder and fix
richpowell91
PostPosted: Sun Dec 30, 2012 1:30 pm Up
In that case have a look in the for sale section on here for someone breaking a 206 or see if anyones got one for sale.
Otherwise have a try at a local scrapyard, or ebay but be careful some people make you think your getting a display but instead send you a copy of the guide i linked to off here and charge you for it.
storm2284
PostPosted: Sun Dec 30, 2012 1:35 pm Up
Have seen those on eBay thanks for the heads up there though, the guys have tried 2 units and plugs didn't fit. I sound a bit vague only as I haven't done this myself so only going on what I've been told. Will be off to the scrappy tomorrow then! Trust my luck the garros has only done 65k never thought it would be broke already lol
richpowell91
PostPosted: Sun Dec 30, 2012 1:37 pm Up
If you can check it before you pay for it, alternatively it could not be a problem with the display but with the connector plug/wiring for the display.
storm2284
PostPosted: Sun Dec 30, 2012 1:44 pm Up
The pin is Deffo broken to the display but for some reason the solder won't sit and take . So in theory any of the 4 bulb units should work if the plugs do?
richpowell91
PostPosted: Sun Dec 30, 2012 1:53 pm Up
As far as im aware yes, i might have a spare one myself if you can wait to find out till tomorrow?
