Latest: tc.206
Overall: 17147
Online Now [130]:
Visitors: 129
Today: 16209
Total: 116471234
Forums › The Car › 206 Talk › Automatic wiping is annoying
lee1985
PostPosted: Sun Dec 30, 2012 6:06 pm Up
As above, sometimes I feel that it is less efficient than it should be.
Is there any way of having normal intermittent front window wiping?
Firstly I want to be able to disable the automatic wiping (I don't know how to do this) because it rubs and makes a horrible noise when the windows aren't wet enough, and secondly I am wondering if there is a setting that allows normal intermittent wiping? The next position after "auto" is constant steady wiping, usually the one above intermittent in most cars.
Can someone please advise?
PostPosted: Sun Dec 30, 2012 6:13 pm Up
Have you moved the switch marked auto or the stalk to the off position?
lee1985
PostPosted: Sun Dec 30, 2012 8:21 pm Up
Unless I'm not looking properly there isn't an "auto off" setting.
It goes (from bottom of the stalk to top):
Wipers off in general
AUTO
Then fast wiping
Then very fast wiping
There are no more stalk options.
There is a button on the end but that is used to change through your options on the centre console i.e. how much petrol you have to go, miles to next service, average MPG and so on.
Would be grateful to know how to turn it off, even if I am being a bit dumb?
Own a Blue Peugeot 206 GTI 180.
usher
PostPosted: Mon Dec 31, 2012 2:19 am Up
cant especially with a 180 i asked the same on my gti and its not been done before
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
anton1989
PostPosted: Mon Dec 31, 2012 5:25 am Up
Trade Rating: +16
i thought you could turn auto wipers off? or is that just auto lights?
PostPosted: Mon Dec 31, 2012 6:14 am Up
You have either intermittent or auto, not both. Just move the stalk to off and hey presto the auto wipers won't come on automatically when it rains. What you can do though is move your finger 2 inches and move the stalk downwards to do a single wipe. I use that function more than I do the intermittent or normal wipe mode.
If you want them off permanently just disconnect one of the wires on the rain sensor.
bezford
PostPosted: Mon Dec 31, 2012 2:10 pm Up
It is a pain in the a**e having no set intermitent wipe...seems the most common level of rain when the set intermitent would be usefull...usefull 1 sweep every 3 seconds or so...aukward.and annoying.
R.HYDE
paul_c
PostPosted: Mon Dec 31, 2012 3:28 pm Up
Yeah, it never seems to get the wiping at the right time. So I often end up turning it off and doing my own wiper timing 'manually'. Normal intermittent wipe can be annoying too, if the interval is wrong. A good setup seems to be variable time intermittent wiping.
usher
PostPosted: Mon Dec 31, 2012 4:16 pm Up
Thats qhy i like ford wiper stalk you can chanhe the time from skmething like 3 - 10sec
project thread WIP
garage
FAQ
206 gti firedance
bezford
PostPosted: Tue Jan 01, 2013 7:15 am Up
Wipers are damn annoying but so is bad grammar man...
R.HYDE
138Andy
PostPosted: Tue Jan 01, 2013 7:20 am Up
and who cares ?
crocdino
PostPosted: Thu Jan 10, 2013 12:08 pm Up
Is it not possible to fit an indicator stalk off a lower model 206 and do some coding?
GTI 138 facelift - Runabout
335d M Sport - Cruiser
evilmunkey87
PostPosted: Thu Jan 10, 2013 2:01 pm Up
It is quite irritating, mine hardly wipe when its raining, yet if I get a drop from a tree or something, they go mad!
I just swear at them a lot!
206 GTi
Mattie-RS
PostPosted: Thu Jan 10, 2013 3:46 pm Up
Love my intermittent with choice of speed Cool
PostPosted: Fri Jan 11, 2013 8:27 pm Up
In PP2000, go to BSI configuration and disable 'rain-sensor'.
This then makes the 'Auto' setting to be interminent mode.
Do it preferably with a genuine interface as clones are a bit risky for modifying parameters in ECU/BSI.
You might have to search-around for a garage with one, or take your chance with someone's clone near you.
