Latest: tc.206
Overall: 17147
Online Now [46]:
Visitors: 45
Today: 31416
Total: 116486391
Forums › The Car › 206 Problems › Failed emmisions, high CO2 level
2judge1
PostPosted: Wed Jan 02, 2013 4:33 pm Up
Hi all, just had my mot done the other day and it failed on co2 emmisions, what can cause it to be high as all the other readings are ok. Ive changed the spark plugs as they were worn, car feels nippier and responsive so hoping that is the cause but here are the test results;
Fast Idle
CO Max Limit=0.300 Actual Value=0.565 Fail
HC Max Limit=200 Actual Value=77 Pass
Lmba Max Limit=1.030 Actual Value=1.027 Pass
Second Fast Idle
CO Max Limit=0.300 Actual Value=0.507 Fail
HC Max Limit=200 Actual Value=93 Pass
Lmba Max Limit=1.030 Actual Value=1.025 Pass
Natural Idle
CO Max Limit=0.500 Actual Value=0.364 Pass
Also the cat was changed 12months ago so hoping that hasnt gone already. Any advice would be great Thanx
Tolkienfan001
PostPosted: Wed Jan 02, 2013 4:35 pm Up
Trade Rating: +13
Might help to tell people what engine etc?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Wed Jan 02, 2013 5:15 pm Up
Car got a good a goof service history?
2judge1
PostPosted: Wed Jan 02, 2013 5:23 pm Up
its a 206 glx 1.4 petrol x reg
paul
bezford
PostPosted: Thu Jan 03, 2013 5:30 am Up
Service the engine...oil and oil filter.air filter.fuel filter...clean the plugs or replace...take it for a good thrash around for 20-30mins....then just before the retest take it for a good thrash again just before u hand it over.
R.HYDE
PostPosted: Sat Jan 05, 2013 9:53 am Up
High CO is excess fuelling.
As above get a full service, plugs, oil change and filters.
Also make sure that the car is up to temperature and still hot when tested; a good run before the test should be enough.
With low(ish) HC (hydrocarbon) reading your engine itself looks to be in good condition.
EDIT1: does your temperature gauge show the vehicle is getting up to correct temperature. A defective thermostat means the engine won't get up to temperature and the ECU will supply excess fuel to the "cold" engine.
Also note that there are at least 2x temperature sensors on the 1.4 - one is for the ECU and one is for the gauge. If the sensor sending the temp to the ECU is defective the ECU will over fuel the engine. In this instance the gauge, if the gauge sensor and thermostat are in good order, may show that the engine is hot but the sensor for the ECU will tell the ECU that it is cold and the ECU will over fuel the engine.
EDIT2: A good CAT that is up to temperature will clean up slight over fuelling so that it is not seen at the exhaust. So high CO at the exhaust means it is probably worse pre-CAT.
If the above doesn't cure it then injector, CAT or possible ECU are suspects and a code read (does the 1.4 petrol store codes?) is very worthwhile.
A long but good read follows. Note the paragraph where I have inserted **** before and after. A good mechanic can easily do this check.
NOTE: A new CAT will disguise a fault for a while but if the fault isn't fixed it can, in a short while, destroy that expensive cat:-
* Carbon Dioxide, is an indication of the completeness of burn, the more complete the burn, the higher the CO2 reading.
* Carbon Monoxide, is an indication of the air: fuel ratio, too much fuel results in a high CO reading.
* Hydrocarbons, is an indication of unburned fuel exiting the exhaust, the more incomplete the combustion, the higher the HC reading.
* Oxygen, is an indication of either incomplete combustion or an air leak. Air: fuel ratio too weak, low combustion efficiency and a pre or post- combustion air leak will cause a high O2 reading.
* Oxides of Nitrogen, is an indication of combustion temperature, low compression pressure, retarded ignition timing and rich mixture will all result in lower NO2 readings. When considering carburettor cars or basic injection cars, emission faults are relatively straightforward to diagnose.
It’s often good experience to have a play with the settings and note the responses. I.e. pull off a plug lead and note the increase in HC but the decrease in CO. Over-richen the idle mixture and note not only the increase in CO but also the decrease in O2. Lean off the idle mixture excessively and note initially the drop in CO and increase in O2 but then note the slight increase CO as the mixture leans off still further. Change the ignition timing and note the changes in CO, O2, and HC. Experience is, as always, a great teacher. It is important to note that if experimentation is attempted with a car equipped with a catalytic converter then irreversible damage may occur.
The main problem encountered with catalyst/ lambda equipped cars, besides the panic attack we all suffer from when the customer says can you fix it, is the extra components which can have an effect on the overall emissions compared to the conventional carburettor or basic injection car. The cars should be running in closed loop, which basically means the injection ECU is constantly monitoring the cars exhaust emission levels and will the modify the fuelling/ ignition levels accordingly, this process takes place many times a second and in a perfect world should never need further attention. The problem with this system is identifying the failed component as all components in the system work together Most modern ECU’s with this system are intelligent ECU’s with the built in facility to ignore specific sensors which can compound the problem.
The next problem that you will be faced with, with many emission related problems, is that a catalytic converter in good condition can and will disguise the actual fault. This will only happen for a relatively short time before the cat becomes polluted and causes a more pronounced fault (see technical tips on catalysts). Garages faced with this scenario will normally condemn, and replace the converter without checking any further. Although the fault will still be there, this will once again disguise the fault for a short while, but be warned the customer will be back. Probably with a warranty claim against the new cat wrongly believing it to be the cause of all his problems, including his flat spare tyre.
Some cars are equipped with a pre-cat emission test pipe or port into which you can plumb you gas tester. This simplifies matters greatly.
Because of these problems it can be very difficult to differentiate faults with emission control systems. Work through the system logically testing and investigating all avenues. To run the risk of repeating ourselves it is important to check the basics out first.
Check the basic engine tune; check plugs, leads, cap, rotor, air filter etc. Make sure the engine condition is ok (see vacuum testing tech tips). Ensure that the proper testing procedure is carried out, i.e. ensure the engine is fully warmed up and the sniffer pipe is fully inserted into the exhaust etc. All basic stuff, but you would be surprised at how many people change ECU’s etc without even taking a look at the plug condition. Don’t take the customers word for it check it for yourself. You could save yourself a lot of time. You should ensure that the data that you are using as a comparison is accurate. Ensure that it is correct for the car, inc. year, cc model etc. We’ve all, at one time or another spent far too long chasing our tails as a result of a simple oversight or misread number/spec. Test the car, check the emissions at all the required rpm levels and either print out the results or write them down. As a rough guide the expected levels of emissions with a catalyst cat with closed loop injection system are as follows; CO 0.3% max. HC 75 PPM max. CO2 14.5% min. O2 Probably the most common mistake made is when the lambda reading is incorrect. Lambda refers to the air fuel ratio, it is a reading which is calculated from the other emission readings (lambda (l) comes from the Greek word for balance). When faced with a car that has failed the emission test on lambda reading the most common response is to condemn the lambda sensor. This guesswork will sometimes pay dividends but more often than not you will have made an expensive mistake. The lambda reading on a gas tester is, to repeat, an indication of the air to fuel ratio, too high a lambda reading relates to too much oxygen. Too low a reading relates to too much fuel. Check the other readings before condemning the lambda sensor.
The voltage reading from the lambda sensor is often a very good place to start with your diagnose of an emissions failure fault. The lambda sensor can be used as a pre-cat emission tester when used with either an accurate voltmeter or an oscilloscope. With the engine up-to normal working temperature, check the output of the sensor wire, normally black with Zirconia sensors, you should expect an output of 0.2 – 0.8 volts fluctuating between these reading approximately 2 – 3 times per second. If the output voltage is lower than this, i.e. 0 – 0.2 volts there will be a lean running or excess oxygen problem. If the voltage is higher than this, i.e. 0.8 – 1.2 volts then there will be a rich running or excess fuel fault. A point to note is that conventional Zirconia sensor is not capable of producing a voltage above about 1.3 volts; if the voltage exceeds this then there will probably be an earth fault with the sensor. Some cars notably Rover have different requirements in respect to internal lambda connections, should you measure a voltage above 1.3 volts it might be worth checking for a lambda sensor mismatch fault.
If the fault is a high lambda reading, with a high O2 reading but with normal CO and HC readings, the most common cause is post combustion air leaks. A small exhaust system air leak will leak air into the exhaust before any blows can be detected. Only a small volume of clean air introduced into the exhaust will cause a car to fail the MOT test.
Various manufactures have had their problems with exhaust air leaks. The Ford Mondeo is a notable example, with various modifications to the manifold sealing ring having been carried out to prevent such an occurrence. Other cars such as Nissans are fitted with a drain hole in the rear silencer. You may need to temporarily bung this drain hole up to prevent a MOT failure. Check these first before condemning or even checking other emission parts.
An air leak after the lambda sensor, i.e. exhaust silencer/joint etc leak, will cause the O2 reading to be high and all the rest to be normal. If the air leak is before the lambda sensor, i.e. manifold/ down pipe, then a diluted exhaust gas will be monitored by the lambda. This will cause an inaccurate reading at the ECU, which will, in turn, cause extra fuel to be injected by the injection system, which will effect the CO, HC and lambda readings. The amount that these readings are out will obviously depend upon the quantity air being introduced into the exhaust. Often you will find that the CO and HC readings can remain normal due to the catalytic converter cleaning them up. This can be very difficult to diagnose, as above a pre-cat emission test pipe would be a great help but is not always available.
We mentioned earlier that a cat will often clean up a rich running fault at the expense of its life span. It should be noticed that the cat of a rich running car would run much hotter. The customer will often pick this up by reporting a strong egg like smell which they will be experiencing much more frequently than the normal egg like smell emitted when a cat is warming up. A discoloration of the actual cat body may also be noticed, this will be similar to the discoloration experienced when heating up a piece of steel. I.e. it will start with a light straw colour turning to a blue colour in extreme cases. Should this discoloration be noticed then you could be certain that the car is either suffering from a rich running fault or there has been neat fuel passing through the engine (possibly bump starting the car?). Moving on, when presented with a cat, with this discoloration, returned for warranty, Fuel Parts UK would reject the claim for this very reason. So please be careful.
**** Rich running (high CO) problems are caused by many faults and can be relatively easy to diagnose (famous last words?). Start again with the lambda sensor, measure the output voltage (remember a high voltage indicates a rich mixture). If the voltage is high you can be sure that the fault is before the cat. If the voltage is normal but the CO emissions are high you should suspect a cat fault. ****
If the fault is before the cat, check to see if the vehicle is equipped with an ECU capable of self-diagnosis. If so is the warning light on? Interrogate the ECU and check the faults logged. Should no faults be logged, and there’s a high lambda voltage, then you should suspect an emissions component that is not monitored directly by the self-diagnostic system. Examples are the fuel pressure regulator, or a fuel injector that has drifted away from the O.E.spec, but not necessarily failed. An ECU on a car in this situation with self-diagnosis will often show a lambda sensor failure fault purely because of the high voltage being relayed back to the ECU. Once again the instant reaction to this would be renew the lambda sensor, after all the “ECU says it’s faulty”. This would be a costly mistake; a faulty lambda rarely gives too high an output voltage, unless there is a mismatch fault as above. You need to check further to find the route cause of the problem.
If the lambda voltage is normal, the self-diagnosis has no faults stored, the exhaust is free from air leaks but the CO emissions are still high then you should suspect a cat fault (see earlier technical tips for details).
You should also check the lambda sensor signal response. With the car up to operating temperature and the car ticking over, connect a voltmeter/ oscilloscope and monitor the voltage, blip the throttle and check how quickly it responds to the change in mixture strength. It should be almost immediate. Lambda sensor response time slows down over its life; this is the main reason why some vehicle manufactures recommend a specific mileage change. Carbon build up, heat stress and corrosion all play a part in the reduction time of the sensor. The reaction time of a lambda governs the mixture control throughout the range, and it is imperative that it is checked. A slow response results in delayed mixture control. If you have any doubts, renew the sensor, this will not only help to clean up the emissions can also rejuvenate a cars performance in the same way that renewing a worn set of spark plugs can. This will be discussed further in a future technical tips issue.
Whilst all the above should be taken as a guide the overall moral to the story is not to be blinkered by the first fault you come across. Check, check and double check, explore all avenues before renewing expensive parts. All faults have a logical conclusion; it’s just finding them.
bezford
PostPosted: Sat Jan 05, 2013 11:33 am Up
Get a life...i left school twenty years ago thanks...just check wot i said because while all that is true its soooo longwinded it will confuse rather than aid....nothing personal kandibarrett but if all answers were so drawn out id buy a bike...basicaly.
R.HYDE
PostPosted: Sat Jan 05, 2013 12:51 pm Up
Then just read the first 5x paragraph. They are my diagnostic and suggestion.
As stated in my post the rest is an interesting read - if you aren't interested don't read it.
Why so rude - if you left school 20 years ago you are old enough to have learnt a few manners. This not your request for help and I don't see anything in my post that is offensive.
Your post doesn't make any mention of possible leaking injector, defective CAT, jammed thermostat or ECU temp sensor not working. You suggest a couple of things as an almost certain fix when almost every symptom can have many causes.
Your suggestion may work (probably will) but there could be many other causes and the thermostat and engine temp reading is simple and free.
EDIT1: If you look at the list of some of the cars I have owned you might figure out that I left school before you did. I don't really know why it is relevant but as you think is has value I thought I would inform you.
EDIT2: get a life? If you note the big gaps in my posting that is usually when I am taking disadvantaged teenagers trekking in the rain forests or as a volunteer building schools in Africa. When I am at home I am usually helping my son with his track car(s) or my daughter with her property renovation business. I am happy with my life.
PostPosted: Sat Jan 05, 2013 2:36 pm Up
It was long winded, but also a usefull post. Especially if a service does nothing.
bezford
PostPosted: Sat Jan 05, 2013 4:45 pm Up
Yeah fair enuf...i just feel people want short sharp fix and not long answers and i know its not always possible to do just a little too long...if u can be a little more concise you will certainly bring a valueable aid...cheers.
R.HYDE
PostPosted: Sat Jan 05, 2013 5:01 pm Up
Some people like to understand why. Others like a short just "try this." The first part of the post was "try this or maybe this." The rest was if you want to know more read on.
It is up to those looking to read or skip and not for us to tell anyone which is the right thing to do.
For some time is more precious than knowledge; for others the priority is reversed.
PostPosted: Sat Jan 05, 2013 5:54 pm Up
I love this site for technical advice and guidance.
www.autoshop101.com/
