Posted: Mon Jan 07, 2013 5:47 pm |
If you have the gauges I have described then you have the standard dash. If you have an oil temp gauge then someone has fitted a different dash from a higher spec car.
Posted: Mon Jan 07, 2013 6:04 pm |
No got no oil temp so got proper ones in just gotta sort this mileage problem out
Posted: Mon Jan 07, 2013 6:11 pm |
Sounds like replacement dash panel. Get a Haynes manual - it is easy to change the dash panel (even without a manual.)
Lower the steering wheel to lowest position. Starting at the bottom carefully prise off the panel surround. A single screw is revealed that holds the dash panel in place.
Posted: Mon Jan 07, 2013 6:17 pm |
Cheers mate will have a look
Posted: Mon Jan 07, 2013 8:10 pm |
What was that you said about unreliable info or bad advice given???the facts are vital...u cant give advice based on a totaly different vehicle...mistakenly or not...
Posted: Tue Jan 08, 2013 11:13 am |
bezford wrote: |
What was that you said about unreliable info or bad advice given???the facts are vital...u cant give advice based on a totaly different vehicle...mistakenly or not... |
Thats rich coming from you!!
Milage in a pre plex will show on the dials to whichever is the greatest either on the new dials or ecu.
Basically if you ecu read 90k and new dials are 120k - it will show 120k
Again if the dials show 90k and the new dials show 40k - it will show 90k
Try and get lowest reading dials you can
Hopefully this solves it
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner | |
Posted: Tue Jan 08, 2013 11:20 am |
mattie-rs: useful info on the recorded (displayed) mileage. Thank you.
Posted: Tue Jan 08, 2013 11:26 am |
No worries, thats for pre plex (>2002ish) only though
Posted: Tue Jan 08, 2013 11:46 am |
That's my daughter's car then; thank goodness as I am not sure I would want the problems that plex brings.
Posted: Tue Jan 08, 2013 11:51 am |
I wouldnt even want to touch the electrics on a plex model
Posted: Tue Jan 08, 2013 2:03 pm |
Posted: Tue Jan 08, 2013 7:39 pm |
so youve bummxd each other all over the shop and then it turns out your wrong.......shame!!!!!!!!!!
