Forums › The Car › 206 Talk › fastest 206 on world? |
Posted: Wed Jan 09, 2013 4:41 am |
Posted: Wed Jan 09, 2013 5:07 am |
thats insane!!
Posted: Wed Jan 09, 2013 5:40 am |
Why's the EML on?
Posted: Wed Jan 09, 2013 6:14 am |
macca1411 wrote: |
Why's the EML on? |
It's a 206?
Posted: Wed Jan 09, 2013 6:34 am |
Because we are running a standalone ecu parallel to original one
Posted: Wed Jan 09, 2013 7:01 am |
Just remove the bulb!
Posted: Wed Jan 09, 2013 8:11 am |
Yeah I heard if you run a standalone parallel to the original one they can keep the multiplexed shizzle. I'm sure it's not new news but I always remember Jamie's anti-climax thread because Sandy Brown couldn't perform the upgrade without issues.
That car sounds mental.
Posted: Wed Jan 09, 2013 12:55 pm |
I dont think Sandy wanted to risk the car not working if he removed half the engine loom. It can be done though. For example what knock on effect does removing the cars control of the throttle have on the ESP system?
Posted: Wed Jan 09, 2013 1:10 pm |
Edward wrote: |
I dont think Sandy wanted to risk the car not working if he removed half the engine loom. It can be done though. For example what knock on effect does removing the cars control of the throttle have on the ESP system? |
I would imagine the ESP would be in constant fault, i think this was one of the reasons Jamie didnt do it.
Not sure but maybe you could write the control of the ETB out but then imagine it still cutting detonation with full throttle still applied.
I think the only available function would be the brakes, by then you might aswell just have it completely disabled
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner | |
Posted: Wed Jan 09, 2013 2:00 pm |
Ohhhhh I messed myself
Posted: Wed Jan 09, 2013 2:35 pm |
His flyby video is mental!
Posted: Wed Jan 09, 2013 3:36 pm |
wow
Posted: Wed Jan 09, 2013 3:51 pm |
That exhaust note on the fly by is perfect !!!
Posted: Wed Jan 09, 2013 3:56 pm |
mega car!
2000 gti 138,tein superstreet coilovers front,tein adjustable shocks rear,22mm rear arb,carbon fibre strut brace, 6 point omp cage,fibre glass bonnet,polycarb windows,406 v6 brembo 4 pots,carbon Lorraine rc6 pads,brembo 307hdi front discs,406 v6 master cylinder,braided hoses all round,306 gti-6 brake reservoir,abs removed,4.9 cwp with 3j driveline plated lsd,compbrake quickshift,k&n filter with cold air feed pipe,4 branch mani,decat,sportex straight thru race system,mocal oil cooler,group n engine mounts,omp bucket seats,omp steering wheel,battery relocated to boot,4 point harnesses,15'team dynamics pro race 1.2 on Michelin slicks | |
Posted: Wed Jan 09, 2013 4:11 pm |
