Online Now [1043]:
Visitors: 1042
Today: 103049
Total: 151594764
Forums › The Car › 206 Problems › Display bulbs
Display bulbs
14hdi
PostPosted: Wed Jan 09, 2013 7:38 am Up
Best place to get the bulbs for the center display and the air-con display.
Is a 2004 if it makes any difference.
Mr_Akina
PostPosted: Wed Jan 09, 2013 7:40 am Up
eBay?
Check out my photos on Facebook
PostPosted: Wed Jan 09, 2013 10:50 am Up
it makes no diff. if it's 2004 or 2008 :D,buy the tungsram brand,it's the best
PostPosted: Wed Jan 09, 2013 10:53 am Up
If you mean the MFD, then they are 509t, readily available at any accessory shop. The AC display I think uses SMD which will need soldering in. Not as easy available and more work to change.
14hdi
PostPosted: Wed Jan 09, 2013 12:51 pm Up
Nope, on the ac display the bulbs can be removed by twisting. Dont think they are the same as the MFD. Thanks for the 508T ordered them already.
14hdi
PostPosted: Sun Jan 13, 2013 10:10 am Up
As you will see there i ordered/miss read it and got 508t so they are very dim. Just ordered the 509T. Take two.
