Online Now [874]:
Visitors: 873
Today: 140939
Total: 157446418
Forums › The Car › 206 Problems › Engine ecu faults
Engine ecu faults
Antknee
PostPosted: Fri Jan 11, 2013 11:30 am Up
Bit of advice would be good please, not sure what exactly all these mean
PostPosted: Fri Jan 11, 2013 11:47 am Up
you need to fix the permanent faults first,as the Intermittent ones can be caused from the first 2,so you have to clean the EGR valve,or replace it,but do the cleaning first.
And the second one,you need to replace the Diesel filter with a OEM one
Big_Rich180
PostPosted: Fri Jan 11, 2013 11:48 am Up
I had the clutch fault on my 180 after the clutch was done, presumably there is a sensor that doesnt get re-connected
PostPosted: Fri Jan 11, 2013 11:50 am Up
try to get the fault codes,that will help us more
you have an HDI or GTI ?
Antknee
PostPosted: Fri Jan 11, 2013 11:53 am Up
thanks for that, im guessing the first one is just because i have the egr unplugged, i have no idea about the ecu one though?!
Antknee
PostPosted: Fri Jan 11, 2013 12:03 pm Up
Its a 1.4 hdi all i have at the minute is that pic unfortunately
PostPosted: Fri Jan 11, 2013 12:12 pm Up
Antknee wrote:
If you press ENTER when one of the faults is highlighted (like the top one) it should open up another window which will explain the fault in more detail and sometimes give a guide to the solution.
Antknee
PostPosted: Fri Jan 11, 2013 12:14 pm Up
macca1411 wrote:
Antknee wrote:
If you press ENTER when one of the faults is highlighted (like the top one) it should open up another window which will explain the fault more
ahh i didn't realise that! nice one Razz
14hdi
PostPosted: Fri Jan 11, 2013 1:13 pm Up
Clutch switch fault is not in the engine bay. This is on the pedal to tell the ECU the clutch is depressed. (should be able to see it if you stick your head in the foot well.
Antknee
PostPosted: Fri Jan 11, 2013 1:16 pm Up
cheers will have a look in the morning
Antknee
PostPosted: Tue Jan 15, 2013 6:52 am Up
2 of the fauls seem to have gone for now, it's just these 2 that keep coming up now
