Online Now [1366]:
Visitors: 1366
Today: 448153
Total: 153843119
Forums › The Car › 206 Problems › Slightly confused
Slightly confused
ali_craig
PostPosted: Sat Jan 12, 2013 6:59 pm Up
Hi forum
Im currently changing the interior of a 206 gti 138bhp to the 180 version,
Is there any specific a need to do changing the front seat over,a got told off my pal a would need to let the circuit die until a could disconnect the air bag conectors,any truth in this?
Cheers for any help
Ali
please help!
PostPosted: Sat Jan 12, 2013 7:06 pm Up
Make sure you shut down the BSI correctly, disconnect the battery and leave the side lights on to drain all the power out the system then disconect the airbags.
ali_craig
PostPosted: Sat Jan 12, 2013 7:30 pm Up
How is it a shut the bsi down,is it the battery and lights bit?
please help!
DanT
PostPosted: Sun Jan 13, 2013 5:50 am Up
www.206info.co.uk/Foru.../t=95.html
BSI procedure all covered there mate Smile
ali_craig
PostPosted: Sun Jan 13, 2013 7:28 am Up
onSo is it just the disconnection of the battery and reconnection of the battery bits a should b looking at?
please help!
DanT
PostPosted: Sun Jan 13, 2013 8:12 am Up
Yeah follow the procedure for disconnecting, give it 15-20 mins before messing with anything airbag related.
Do whatever you've got to do then follow the procedure for re-connection
Sorted!
ali_craig
PostPosted: Sun Jan 13, 2013 9:01 am Up
Ok a will give it a try and let u now how a get on,
please help!
ali_craig
PostPosted: Thu Jan 17, 2013 7:28 am Up
Seats are in and lookin hot, next thing a want try and find in a custom surround for the clock above the centre vents,any idea where to get 1?
please help!
