Online Now [1123]:
Visitors: 1121
Bots: 2
Today: 305323
Total: 151425062
Forums › The Car › 206 Problems › PUG 206 Running Temperature
butch1978
PostPosted: Sun Jan 13, 2013 8:30 am Up
Hello, i am stuck with my PUG 206
For a long time now the temperature gauge doesn't go above 70 even if i give it a hard drive. The only time it will go to around 90 is if i run it at a fast idle for around 10 mins.
I decided to give it a coolant change incase there was any blockage. I used a branded coolant flush, and refilled with antifreeze, hoping this would cure the problem (as there was alot of gunk that game out on the first drain) but it still wont go over 70 unless i do a fast idle. Can anyone advise me on what could be wrong?? could the thermostat need replacing?? Also just to add that the heater is warm, but not as hot as when i put it on when i have had it on a fast idle!
Martin
DanT
PostPosted: Sun Jan 13, 2013 9:13 am Up
I'd start with replacing the Thermostat for sure.
butch1978
PostPosted: Sun Jan 13, 2013 9:15 am Up
I'll give that ago. Thanks for your advise
PostPosted: Sun Jan 13, 2013 10:10 am Up
+1 change the thermostat. It will also improve fuel consumption by 2 - 3 mpg.
You will probably find it runs at about 80 rather than 90; not all but most seem to.
You will probably find the fan cuts in at about 90; again not all but most seem to.
These temperatures are lower than most expect but that is what these seem to do.
A blockage will cause an over-heat not running cool.
PostPosted: Sun Jan 13, 2013 1:33 pm Up
IS this a diesel or petrol? The diesels will run cooler than the petrol anyway.
butch1978
PostPosted: Sun Jan 13, 2013 1:35 pm Up
It's a petrol
PostPosted: Sun Jan 13, 2013 3:23 pm Up
it should reach 90oC when it's warm,then it open when it's 95-97oC,so change the thermostat,and bleed the coolant system .
butch1978
PostPosted: Sat Jan 19, 2013 9:56 am Up
Hi
just to let you all know i replaced the thermostat today, and it all seems to be running fine. I did however manage to shear the bleed bold off the engine block, but managed to sort it out. What was strange is that there was no old thermostat to replace!!!
Does anyone know why this could be?
PostPosted: Sat Jan 19, 2013 10:09 am Up
Someone's obviously taken it out. Shouldn't matter really, just would take longer for he engine to warm uP.
