Posted: Sun Jan 13, 2013 10:07 am |
Just purchased a 206 gti 140 bhp V reg and I have a concern regarding the idle.
I was driving in london last night and on standstill the idle sometimes dropped to just below 800rpm, felt like it may cut out, however it didn't.
I don't know if this makes any difference to what it could be... but when I put the A/C on, straight away it went back to normal 900/1000rpm
Any help would be much appreciated
Cheers.
Posted: Sun Jan 13, 2013 10:14 am |
Posted: Sun Jan 13, 2013 10:25 am |
As mentioned idle stepper motor would benefit from a clean, i'd be inclined to remove the whole throttle body myself and give it a good going over but you might find thats not necessary.
Posted: Sun Jan 13, 2013 10:41 am |
How about cleaning the idle control valve, would that be necessary
Posted: Sun Jan 13, 2013 11:26 am |
Idle control valve
Idle stepper motor
Same thing different name.
Posted: Sun Jan 13, 2013 1:37 pm |
Isnt that the normal idle range? Is on my gti anyway, unless your engine is struggling to tick over?
Posted: Sun Jan 13, 2013 3:30 pm |
Posted: Mon Jan 14, 2013 6:31 am |
I don't think the idle is meant to be at just below 800rpm pal, engine struggles to stay on when it happens. However put the A/C on and it's fine again
Posted: Mon Jan 14, 2013 6:32 am |
Cheers Timon will use that one. Pictures always help
Posted: Mon Jan 14, 2013 11:33 am |
Used both the guides, couldn't find the map sensor on my engine however. Will update on results of the new year clean
Posted: Mon Jan 14, 2013 11:56 am |
Can't help with picture of your map sensor location as I only have access to 1.4 8V at the moment.
Posted: Mon Jan 14, 2013 12:54 pm |
Can you not explain it?
Posted: Mon Jan 14, 2013 1:16 pm |
I could if I had a quick look at the car first and I am still at work. It's a long time since I have worked on a 1.6 and the MAP sensor may be in a different place than the 1.4 I will have access to.
Hopefully someone here will explain where the 1.6 MAP sensor is located.
Posted: Mon Jan 14, 2013 2:57 pm |
I haven't got a 1.6, got a gti pal
Posted: Mon Jan 14, 2013 4:47 pm |
Sorry, but either way it will be different to a 1.4 8V.
