Online Now [347]:
Visitors: 345
Members: 1
Today: 47781
Total: 157712469
Forums › The Car › Request a how-to › how to install led rings (angel eyes) on Headlights.
traffica1
PostPosted: Tue Jan 15, 2013 5:53 am Reply with quote Up
Hello,
I will buy some led rings and i would like to apply them around the low and high beam. any idea on how to do the latter?
Thank you
jimjam19927
PostPosted: Tue Jan 15, 2013 6:13 am Reply with quote Up
If you want to do it to factory headlights I guess you would need to first remove the headlights and split them. There are loads of guides on here how to do that with regards to masking headlights. Usually with a heatgun or hairdryer and knife and patience or oven bake. Drill small holes where the wiring will pass through. Then glue the rings where you want them feeding the wiring to them. Need some glue that would withstand high temps. Then refit the headlights. Then wire the led rings to the sidelights? or wire them to a switch.
TBH angel eyes are cheap as now a days probs about £50 for a seconf hand pair for your pug so save the bodge and tack look and get a set of proper angel eyes.
Member: 685
I Over Use Smilies Razz
traffica1
PostPosted: Tue Jan 15, 2013 6:19 am Reply with quote Up
Thank you for the reply
This is my car currently, one ring has stopped working, and i am willing to replace it.
That's the whole idea behind it actually.
Thanks again
meady
PostPosted: Tue Jan 15, 2013 7:03 am Reply with quote Up
Trade Rating: +45
So you already have angel eyes and not standerd headlights ?
TEAM - I HATE FACEBOOK Smile
traffica1
PostPosted: Tue Jan 15, 2013 7:07 am Reply with quote Up
yes this is a photo of my car, all i need to knwo is how to replace a ring which malfunctioned.
i can buy the ring on its own, but i have no clue how to input it>
PostPosted: Tue Jan 15, 2013 8:04 am Reply with quote Up
You sure its not just a case of pulling the led out from the ring and changing that?
traffica1
PostPosted: Tue Jan 15, 2013 8:14 am Reply with quote Up
can i do that without splitting the headlight? any ideas?
PostPosted: Tue Jan 15, 2013 8:39 am Reply with quote Up
I did on my set, they popped out the bottom of the halos from behind.
meady
PostPosted: Thu Jan 17, 2013 10:42 am Reply with quote Up
Trade Rating: +45
As above if they are genuine angel eyes there is no need to replace the ring, you should be able to follow the cables into the bottom of the light for the ring that is broke , normally they are just pushed in so give it a wiggle to get it out and just change the necessary bulb Smile
  Quick Reply
Username:
Message:
Quote the last message
