Online Now [1128]:
Visitors: 1127
Today: 116891
Total: 155210462
Forums › The Car › 206 Talk › from drum beam to disk beam (how easy is it)
Forum Index › 206 Talk
ricksgti
PostPosted: Thu Jan 17, 2013 9:06 am Up
right i have come to the conclusion on my brothers car this axel and brakes are screwed..
so he has a 206 1.4 8v 2003 and has a drum beam
is changing 2 a disk beam of a higher model a fairly easy swap
i no bolting the axel up will be same but my question really is the brake lines and handbrake cables
iv had enough of the drums and think its time to go disk!!
please help me!!
(if its fairly easy wat axel would u recommend)
anton1989
PostPosted: Thu Jan 17, 2013 9:27 am Up
Trade Rating: +16
if you have search its been covered mate
its very easy you just need the the rear axle and hanbrake cable and new brake lines need making up
PostPosted: Thu Jan 17, 2013 12:14 pm Up
axle will bolt straight on just need disc brake lines and handbrake cables
has it got abs if so make sure the axle has the right type of plug as plexed and pre plexed abs axles are different!
