Online Now [461]:
Visitors: 459
Bots: 2
Today: 31810
Total: 155332652
Forums › The Car › 206 Problems › Central locking gone nuts !!?@£?! Please help =(
GaryS22
PostPosted: Fri Jan 18, 2013 9:00 am Up
Okay, so my 206 GTI HDI has been sitting for a month or so and the battery died, got the car jump lead started in one go and runs fine.
I took it to the garage yesterday to have the door replaced after being majorly dented by a (beep). Now I have the car back, the central locking has gone all hay wire.
(From the key) when I unlock the car it locks itself again straight away. Then when it stops after a bit of clicking unlock, the key does not work the c/l at all. Start the car and come out, then it will lock from the key. Its acting temperamental from the lock button on the dash also.
Could this be anything to do with the flat battery or could it be the e/w & c/l have not been fitted properly with the new door and causing a connection problem??
Any help greatly appreciated folks!!
Gary
If in doubt flat out !
Tolkienfan001
PostPosted: Fri Jan 18, 2013 9:16 am Up
Trade Rating: +13
Have you checked the battery does not need replacing? Could also be one of the locks. Think you can test it. Something to do with the interior light won't work on the door with the faulty lock.
Think you can also try a BSI reset.
I am sure these are some of the suggestions I have seen on here by some of the more knowledgable members...
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Fri Jan 18, 2013 9:28 am Up
Take it back to the people that fixed the door and get them to fix the locking system. It is their problem not yours.
p**s poor that they didn't check this before handing the car back to you.
