Online Now [625]:
Visitors: 624
Today: 203319
Total: 155292334
Forums › The Car › 206 Problems › car wont start
car wont start
zezotornado
PostPosted: Fri Jan 18, 2013 12:30 pm Up
Hi,
yesterday my car didn't start and I thought that the problem is the battery so I changed it and it works perfectly but today it wont start again I heared only a "click" sound and I tried to check the fuse box under the bonnet and I discover that when I remove this fuse ( see the pic ) and plug it in again the car start normally .
any idea what is the problem ?
PostPosted: Fri Jan 18, 2013 1:12 pm Up
Fuse 4 is BSI fuse. Don't think it is 70A as the following suggests though.
www.autofuseboxdiagram...x-diagram/
With a small screw driver you may be able to push the contacts in the fuse holder closer together to make a better contact or just replace the fuse. The contact faces are probably dirty. Tight contacts and remove refit the fuse 2 or 3 times is often enough to clean the contact face and cure the intermittent fault.
Have a look at shutting down BSI and BSI reset procedure. You ought to follow that if you are removing and replacing these fuses.
zezotornado
PostPosted: Fri Jan 18, 2013 2:28 pm Up
Thank you so much
I will try to do that and I hope it solve the problem
appreciate your reply .
PostPosted: Fri Jan 18, 2013 3:01 pm Up
just try to replace the fuse,with a new one,because sometimes the fuse get faulty with time,do this and try it tomorrow morning
PostPosted: Fri Jan 18, 2013 3:04 pm Up
Are the fuse blades clean or dirty looking?
PostPosted: Fri Jan 18, 2013 3:45 pm Up
Spray the fuse holder with one of these may also help. Useful to keep as it looks like quite a few have used it to clean MAF.
www.halfords.com/webap...yId_255223
www.maplin.co.uk/conta...aner-25340
zezotornado
PostPosted: Fri Jan 18, 2013 3:48 pm Up
I replaced the fuse and this is the old one
PostPosted: Fri Jan 18, 2013 4:00 pm Up
Looks like the contacts are quite strong. You can see where the fuse has been scrapped clean removing it. Keep it as a spare it was probably just dirty connection that has now been cleaned up just replacing the fuse.
Good luck.
zezotornado
PostPosted: Fri Jan 18, 2013 4:15 pm Up
thank you appreciate the help
and I hope it is the end of the problem i will discover that in the next days
I will keep you update so if someone have the same problem this post will help him .
PostPosted: Fri Jan 18, 2013 4:37 pm Up
You have been good to spot the specific fuse. Most people would have pulled and reseated each fuse and relay in one single go. Problem fixed but they would never have known which fuse or item was at fault.
Well done to you.
PostPosted: Fri Jan 18, 2013 4:42 pm Up
Keep an eye on it, if you have persistent problems. This was a reoccurring problem on my hdi relating to the fuel pump.
zezotornado
PostPosted: Fri Jan 18, 2013 4:46 pm Up
you had the same issue i mean that fuse ?
PostPosted: Fri Jan 18, 2013 4:51 pm Up
That's because you are looking at / linked to a NON plexed fuse list when the OP's car is MULTIPLEXED Wink
The 10 amp F4 fuse on a multiplexed 206 is for the engine ecu & also the auto gearbox.
PostPosted: Fri Jan 18, 2013 4:52 pm Up
Not that fuse, I was the fuse for the fuel pump. but every couple of weeks I had to change the fuse box. Sold the car as soon as I found the problem. Don't know what caused it, but the fuses kept corroding, looked like an electrical problem.
Check where the fuse sits, see what the connections look like. Could also look at a couple of other fuses, check there condition. there's 2 fuses for the BSI. Mine was probably a problem related to that car, so don't worry!
zezotornado
PostPosted: Sat Jan 19, 2013 10:27 am Up
oops!
today in the morning it start normally but after 1 hour trip I turn it off and it wont start again
i tried to remove the fuse and plug it again but it is not starting
