Posted: Sun Jan 13, 2013 11:33 am |
so ive got a set of jbl components to go in the front and im using the original wiring but adding onto it so it will be long enough to reach the crossover, however connecting the two wires is more trouble than its worth as spade connectors (crimps) arent great and seem loose and soldering is a no go as there isnt enough of the old loom coming out of the speaker hole, so i was wondering if using strip connectors would be alright? the screw type.
cheers
Posted: Mon Jan 14, 2013 4:15 am |
If you mean 'terminal-blocks' then yes.
Posted: Mon Jan 14, 2013 12:37 pm |
Yeah that's what I meant, wasn't sure if they would be good enough. Cheers
Posted: Wed Jan 16, 2013 7:26 am |
Just snip them off and crimp on spade connectors bit of tape around the connections, much easier!
| 1997 106, 2002 206 LX 1.4, 2004 GTHDI,
2008 207 GT, Renault Clio 1.4 Dynamique 2006,
Honda Civic Type R 2004 EP3 Model and a road legal Suzuki LTZ250 Quad Bike
Old Registration Info, Over 2000 Posts
13 Seller Feedbacks | |
Posted: Wed Jan 16, 2013 11:37 am |
Tried crimp connectors pal, there shocking, don't seem to hold very well
Posted: Fri Jan 18, 2013 2:56 pm |
Scotch locks man.
