Latest: dreyfalon
Overall: 17121
Online Now [376]:
Visitors: 375
Today: 23511
Total: 97427275
Forums › The Car › 206 Problems › 206 SW MOT Fail - Problem with lights
skyking_comms
PostPosted: Sat Jan 19, 2013 1:42 pm Up
Hi,
I'm looking to sell my 206 SW 2.0 DT in the next couple of months, but it failed the MOT yesterday due to problems with lights -
- Nearside indicator rear position lamp(s) adversely affected by the operation of another lamp <when turning on indicator with headlights on another light at the top of the rear column (brake??) also turns on and off>
I have cleaned the contacts on the rear light panel connector, checked all the bulbs but still the same problem. Garage said its either a wiring problem or bad earth and that I need an auto electrician Sad
Has anyone else experienced this and if so how did you resolve it?
- Both n/s o/s headlamp aim too low - Thought this was an easy fix but when the garage checked they said the aligners were broken and that I would need new ones. Any ideas what I can do?
I don't want to spend too much considering I'm selling it, so appreciate any advice.
PostPosted: Sat Jan 19, 2013 1:49 pm Up
Bad earth is a common fault for the indicator problem. What headlights are fitted?
skyking_comms
PostPosted: Sat Jan 19, 2013 1:51 pm Up
Just standard 206 lights / bulbs
BobbyD
Lewis
PostPosted: Sat Jan 19, 2013 2:36 pm Up
could be COM2000 unit.
Tivoli LX 1.1
Black GTI 180
White VXR Burg
skyking_comms
PostPosted: Sat Jan 19, 2013 3:44 pm Up
How can you tell?
BobbyD
PostPosted: Sat Jan 19, 2013 6:28 pm Up
Rear lamp is always an earth fault, clean up all connections, including bulb holder, check your using the right bulbs. Are they frosted or crystal headlights? Do they level from inside the car ok?
