Online Now [572]:
Visitors: 571
Today: 127261
Total: 157005015
Forums › The Car › 206 Problems › Gearbox change
Gearbox change
Wesser
PostPosted: Sat Jan 26, 2013 3:59 pm Up
I have got a peugeot 206 1.1 1998 which the gearbox has gone in would anyone be able to tell me if the gearbox from a 1999 Roland Garros would fit it?
Sadako
PostPosted: Sat Jan 26, 2013 4:51 pm Up
be ok as long as the rg is also a tu 8v so will have same ma type box
PostPosted: Sat Jan 26, 2013 5:12 pm Up
I imagine the RG will have different ratios because it's a 1.6. Shouldnt be too different though.
Wesser
PostPosted: Sun Jan 27, 2013 4:11 am Up
Okay cheers will the different gear ratios make much difference?
PostPosted: Sun Jan 27, 2013 5:45 am Up
Doubt it will be significantly different.
Wesser
PostPosted: Sun Jan 27, 2013 6:25 am Up
Will the drive shafts still fit or will they be different?
PostPosted: Sun Jan 27, 2013 7:04 am Up
If i remember correctly, the 1.6 ones at the diff input are slightly shorter so 1.4/1.1 ones slightly leak
Wesser
PostPosted: Sun Jan 27, 2013 7:21 am Up
could i just swap the 1.1 ones with the 1.6 then?
PostPosted: Sun Jan 27, 2013 7:40 am Up
Yes, the 1.6 will fit your car but if you fitted the 1.1 shafts into the 1.6 gearbox they would not fully sit in/mate and leak ever so slightly.
When you get the box just compared the ends which enter the box and you will see what i mean
Wesser
PostPosted: Sun Jan 27, 2013 12:30 pm Up
So if I just change the shafts and box everything will be fine?
