Posted: Sun Jan 27, 2013 11:24 am |
So I discovered a leak on the drivers side in the boot, near the c pillar. It appears to be damp around where the seat belt bolts to the body under the parcel shelf and seems to be running down under the rear bench and onto the carpet.
I did have a leak coming from the rear light a while back and sorted that out so I know that's not the cause.
Anyone have any ideas to where its coming from?
Cheers
Posted: Sun Jan 27, 2013 11:29 am |
Sit inside it and get someone to run a hose pipe over the car, then keep an eye out for where the water appears.
Posted: Sun Jan 27, 2013 11:35 am |
Yeah I'll give that a go when I've got the time, cheers mate
Posted: Sun Jan 27, 2013 12:11 pm |
have you checked under the seats to see if the fuel pump cover has moved or even missing?
Posted: Sun Jan 27, 2013 12:13 pm |
Yeah I've checked that pal and its all good
