Latest: dreyfalon
Overall: 17121
Online Now [493]:
Visitors: 492
Today: 108234
Total: 97511886
Forums › The Car › 206 Problems › Idle concern 206 gti
Go to page Previous  1, 2, 3
Jordy6969
PostPosted: Thu Jan 24, 2013 6:33 pm Up
So you definitely would change the ICV. Would that be in any way affected by the AC being turned on/ off though?
PostPosted: Fri Jan 25, 2013 9:32 am Up
As previously described the AC puts an additional load on the engine so revs will drop lower and stepper motor will try to correct for that.
I could not say 100% that it will be stepper motor but am quite inclined to think so. Will your local scrappy let you try a second hand one and if it fixes it you pay if it doesn't you give it back?
I haven't re-read the whole thread but what checks have you done on MAP sensor or code reading?
Are you sure that the mounting area and hole that the stepper fit into are spotlessly clean.
Jordy6969
PostPosted: Sun Jan 27, 2013 7:24 pm Up
Before I bought the car I checked the ECU for fault codes and it was all clear! I have cleaned the whole throttle body with the specified carb cleaner. I will have to ask the scrappy but I'm not sure if they will. Might have to just risk it, can't be too expensive from there!
What are the checks you can do regarding the map sensor?
Cheers for the help pal
PostPosted: Mon Jan 28, 2013 6:52 am Up
I don't think there are many checks you can do of the MAP sensor unless someone here can give output voltages or you can connect the car to PP and get readings from that. It may be worth removing the MAP sensor and spraying with carb cleaner. It is delicate so no scrapping or scrubing please.
When cleaning the throttle body did you remove the ICV (stepper motor) and clean that and the location it fits into. When the ICV is removed also spray carb cleaner into the hole that the ICV mounts into.
PostPosted: Mon Jan 28, 2013 8:03 am Up
To check the supply voltage disconnect MAP sensor with engine off. Switch on ignition and put a multimeter across terminals 2 and 3.The correct reading should be 5V
To check the operation, leave MAP sensor connected, switch on ignition and put a multimeter across terminals 1 and 2. the reading should be 4.4V
Start engine and leave at idle, check again across terminals 1 and 2. Correct reading is 1.3V
Rev engine in sharp bursts while checking voltage across terminals 1 and 2. It should read 4.4V briefly.
And some people don't think this site has enough technical information. DOH!!!
PostPosted: Mon Jan 28, 2013 9:18 am Up
Macca: thank you; that is useful information.
Jordy6969
PostPosted: Sun Aug 04, 2013 2:18 pm Up
Can you let me know where these 3 terminals are because I am unsure
Page 3 of 3
