Online Now [318]:
Visitors: 316
Bots: 2
Today: 110691
Total: 155980188
Forums › The Car › 206 Problems › deleted
deleted
Quikrex
PostPosted: Thu Jan 31, 2013 11:42 am Up
deleted
mtempsch
PostPosted: Thu Jan 31, 2013 12:21 pm Up
Is the fan coming on as the temperature goes this high?
FWIW,, my RC requires a good high speed run followed by sitting in traffic to move from an otherwise steady 90'C (+/- maybe a needles width), and even then doesn't go very high...
Silvermetallic 2004 206 RC
PostPosted: Thu Jan 31, 2013 12:33 pm Up
Check the fan terminals, sounds like the high speed isnt kicking in at all.
JamieM
Jesus that's high.
Take it back.
Owned 2, both of mine have sat under 90, slightly higher in the summer iirc.
Aegean Blue 206 GTi180
Quikrex
PostPosted: Thu Jan 31, 2013 12:50 pm Up
deleted
PostPosted: Thu Jan 31, 2013 12:58 pm Up
It's the same fan, just the ECU changes the speed it runs at depending upon temp, it should kick into high speed at 93degrees if I remember rightly.
Quikrex
PostPosted: Thu Jan 31, 2013 1:03 pm Up
Cool googling terminal differences now and gonna go and check!
Quikrex
PostPosted: Thu Jan 31, 2013 1:31 pm Up
deleted
PostPosted: Thu Jan 31, 2013 1:42 pm Up
You sure it just doesn't have a leak in the system somewhere?
Any puddles/damp patches under the car when its been stood for a while?
Quikrex
PostPosted: Thu Jan 31, 2013 2:18 pm Up
deleted
PostPosted: Thu Jan 31, 2013 2:22 pm Up
2 litres???!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Quikrex
PostPosted: Thu Jan 31, 2013 2:27 pm Up
deleted
Schumi
PostPosted: Thu Jan 31, 2013 3:27 pm Up
Headgasket failure ?
2005 206 RC RED
Quikrex
PostPosted: Thu Jan 31, 2013 3:54 pm Up
deleted
Deano
PostPosted: Fri Feb 01, 2013 1:07 am Up
Hi ye I have a 140 gti and mine does the same thing only mine done it with the engine before and I have had a new engine put in due to other reasons but the temp still goes to just before the last red line before it starts cooling down I have to put heaters on when in traffic and it's not using water I did ask on this forum and got the same answer that these run hot but if u didn't know about this and your fan failed u would have no time to realise they was something wrong and it would probaly go bang surely Peugeot won't of made them like this I was thinking of changing thermostat but now I might have a look at this fan speed
